felixedo
- Joined
- Jul 15, 2011
- Messages
- 50
- Location
- Missouri Ozarks
- Tractor
- New Holland TC35D / Deere 1026R / Bobcat CT2040
I have a NH TC35D with under 300 hours. Over the years it has not been uncommon to get on the tractor and find that a mouse has lunched on a wire or two. I would trace it down and splice in a piece. This time it's different. There was a major party on my wiring harness and it is SHREDDED. I can't believe the amount of damage. A replacement harness is around $800 and that is just for 1. And just splicing in a section of red wire isn't going to do the trick this time, either. I have gone so far as to order a kit of colored wire to color match the damaged wire. New Holland does a decent job of labeling the wires, so I should be able to identify both ends of the same wire at some point.
The biggest issue is that a number of wires are chewed right down to the termination point. The relay or gang connector is there with a small nub of wire exposed. On most I can identify the color of the wire, but that is all. I am no expert at reading wiring schematics. Most of these parts no longer have the P/N visible on them, but they may have 2 or 3 of the wires identifiable. How do I identify the parts that these are, and how do I connect to them once I do? Is it possible to remove a single wire from a gang type connector and replace it?
Thanks
Thanks
