Ford 445A
   / Ford 445A #1
weathda
Alabama
Farmtrac 665DTC, Kubota L2550, John Deere 310SE, Dresser 175C
Local auction yard has a 445A backhoe on the consignment lot. The yard man says an 80 year old man is selling it to get rid of some of his equipment.
Some research shows it to be a 1987 model. Doesn't look beat up, but has probably sat outside most of it's life. Paint is a little faded and has some rust. Has a few expected leaks on the cylinders. Haven't gotten serious enough to ask for keys yet, but what are some things to look for when checking it out? What's the good, bad and ugly of these tractors?
   / Ford 445A #2
Not much bad or ugly. If 4wd, look for leak in back axle pivot on front axle. Raise up axle with loader and rotate wheels by hand to make sure not much slop.
2WD version, raise the front axle and look for worn kingpin bushings. If through the bushing(s) may have to replace spindle.
Listen to engine. Caracteristic knock normal. Rapping hammer sound not good.
Otherwise, nice tractor to own. Backhoes tend to drag if equipped with 24" wheels, but 28" wheels are good.
When you say backhoe, is it the Ford 764, painted black?
   / Ford 445A
Thanks for the response. It's 2WD. I checked all the lever linkages and foot pedals and they all seemed surprisingly tight and smooth. Will check the things you mentioned. I noticed it has what looks like a shuttle shifter on it with no clutch. It has a little round pedal (switch?) where the clutch is on standard tractors. What's with the little round switch?
I have pictures, let me see if I can get this to work.
   / Ford 445A
Looks like it has a weightblock on the front probably close to 500 lbs?
The right side loader and boom cylinder are leaking. All the other cylinders looked dry.
It's a two stick. The valve bank and swing cylinders were dry, but I'm sure they degreased it good and haven't used it since.
I think it's showing ~1600 hours. Who knows if hour meter is working or not.
   / Ford 445A #5
Nice looking unit. Front weight is for counterbalance of backhoe. Leaking cylinder is easy enough to fix.
The transmission is a torque converter power shuttle 4 forward, 4 reverse speed. The pedal is a clutch switch. The transmission is synchronized in 3 and 4th gear.
Hourmeters didn't last very long, but very well could reflect actual hours.
When you purchase, you'll need the 'true' model number of the loader and backhoe. It is on a metal tag on the LH loader arm and the tower of the backhoe. It is the number that starts 19-... necessary to know for parts.
Not to scare you, but look at oil and coolant for any cross-contamination. Electrolysis or cylinder cavitation, common to diesels in general, is something to look for if no or hidden history. Once purchased, flush cooling system and use an SCA additive type coolant or in short, a coolant made for diesels.
   / Ford 445A #6
Would check for water in the transmission, cracked shifter boot is often the cause, it could ruin the shuttle pump.
   / Ford 445A #7
Very nice tractor! That's the 14' hoe that's also on the 545a,555a, &555b. A very nice, very heavy duty unit! As for the front weights, the side ones are 210 lbs each, if there's one under the front between these it's another 500lbs. DO NOT REMOVE THEM! they counter balance the heavy hoe against the lighter straddle mount tractors (345,445,545's)
As for your foot button, this is out of my 345C manual, but same idea -
   / Ford 445A #8
If you are wondering "why do I need this", because the brakes will not stop the machine and, you have no clutch pedal.
   / Ford 445A
Great information. Thank you all. The "dump switch" makes sense now and it's nice to know how not to use it. I have a few other pictures and it does show the center weight on the front. Few more questions:
1) Do any of you know how much this unit would weigh?
2) Where is the transmission dip stick? Would it be under the loader platform?
3) Does the trans share the same fluid as the hydraulic system with one big reservoir?
4) What would something like this be worth in working order? The buy it now price is $7500. Auction is at the end of the month with 10% premium.
Might go look at closer on Friday and see if we can find a pile of dirt to drive into.
   / Ford 445A #10
The transmission dipstick should be next to the shift stick, attached to the big plug. The hydraulic tank is separate and is in front of the radiator. I would guess the weight about 13k. The price is not that bad in my opinion, if it runs good and works. Look for loose pins or bushings on the bachoe and the loader. I am in CA so my price veiw may be different.
SCAN FOR HAULING AND FINANCING INFORMATION (A51248)
SCAN FOR HAULING...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
WESSEX RMX500 LOT NUMBER 44 (A53084)
WESSEX RMX500 LOT...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2016 FREIGHTLINER...
Polaris Ranger SxS Doors with Bolts (A51573)
Polaris Ranger SxS...
