g738419
Hi all,
Hope you had a nice weekend. In Sweden it was pooring down; autumn has really made its approach.
I have two questions
1. General coolant hose.
I have one small 16mm hose which is about 80cm long and which connects from one larger hose (enging warmer) to the enginge, above the starter. Problem is that when entering the enging, the hose needs to make a small 180 degree turn, which makes the hose to pinch.
How do you usually solve this? I am thinking about bending a cupper pipe and putting it in to the hose, just for the 180 turn....Any other more simplier ideas?
2. When I bought the tractor the foot throttle pedal came on the side. I can see hhow its connected to the thottle and where the spring should go, but I am missing/cant figure out how its suppose to be attached to the floor. I am missing any kind of hings type..... Any picture of a throttle pedal mounted on the floor would help and would be appreciated.
Thanks
Martin
Thanks
Martin
