Results 1 to 8 of 8
  1. #1
    Bronze Member nolarefugee's Avatar
    Join Date
    Mar 2011
    Posts
    50
    MF 135, Ford 4000
    Default Lift Arm Ball Retainer Spring - Ford 4000
    Does anyone have a clear picture or diagram of how these things are supposed to be installed?
    They're for a 73 Ford 4000.
    Lift Arm Ball Retainer Spring - Ford 4000-liftarmballretainer-jpg
    Here's what my lift arms look like, they could have something missing where these are to attach, but I couldn't find good example of how they go on.
    Lift Arm Ball Retainer Spring - Ford 4000-liftarm-jpg
  2. #2
    Gold Member japody's Avatar
    Join Date
    Oct 2013
    Posts
    413
    Richmond & Boydton VA
    Ford 4000 & 5000
    Default Re: Lift Arm Ball Retainer Spring - Ford 4000
    That's the way my lift arms look.
  3. #3
    Join Date
    Mar 2011
    Posts
    50
    MF 135, Ford 4000
    Without the springs in there, the balls fall out. I'm trying to see if anyone has a picture of how they go on to hold the ball in it's socket.
  4. #4
    Join Date
    Mar 2013
    Posts
    127
    ky
    ford new holland
    another simple way to hold them in is just get a string and tie them in. problem solved. i use a string a lot and mine has the clips that work.
  5. #5
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,407
    Lincoln County, NC need new avatar!
    Just a Scag
    After a decade or two of wear on the sockets the clips are a waste of money and provide only false security. Put the balls in the toolbox when no implement is attached to the 3PT.
    Spring is the season of optimism.
  6. #6
    Silver Member showcattle's Avatar
    Join Date
    Jul 2003
    Posts
    177
    Eastern Ohio
    2008 NH 2210, 1988 Ford 3910
    I've changed the ones in the 3910 once. That protrusion to the right of the lynch pin is where they go. There should be a hole in the top side and the bottom side of it. The holes are probably full of rust and mud. Clean the holes out really good. Getting the ends of the clips into the holes is a PIA. The new clips lasted about two years, and broke. Now I just do as RickB said, remove the balls and put them in the tool box.
    2008 NH 2210
    1988 Ford 3910
    1980 Ford 1100 (retired)
    2003 NH TC21 (traded for 2210)
    2005 Dodge QC 2500 4X4 CTD
    6 cows
    1 donkey
    2 dogs
    2 kids
    1 wife
  7. #7
    Join Date
    Mar 2011
    Posts
    50
    MF 135, Ford 4000
    Quote Originally Posted by RickB View Post
    That's what I normally do, but have forgotten before and lost one.
  8. #8
    Join Date
    Mar 2011
    Posts
    50
    MF 135, Ford 4000
    Quote Originally Posted by showcattle View Post
    I'll take a look and see if they're still functional, the springs were not very expensive so thought I'd give it a shot.
Similar Threads
  1. 3-Point Hitch Missing lift arm ball!
    By KenPauling in forum New Holland Owning/Operating
    Last Post: 10-23-2017, 01:35 AM
  2. Ford 4000 lift arm end adjustments
    By oldbeagle in forum New Holland Owning/Operating
    Last Post: 08-07-2014, 06:54 PM
  3. Ford 4000 Owner with PTO and Lift arm problems
    By Rosastringworks in forum New Holland Owning/Operating
    Last Post: 05-31-2014, 12:22 AM
  4. jd 5220 lift arm ball
    By rfhjr in forum John Deere Owning/Operating
    Last Post: 12-08-2012, 08:51 PM
  5. Lift Arm Ball Modification
    By Native87 in forum Parts/Repairs
    Last Post: 11-10-2012, 12:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
