Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Super Star Member txdon's Avatar
    Join Date
    Jul 2003
    Posts
    11,062
    Central Texas
    Kubota L5030HST, Hustler FasTrak
    Default Dadís Ford 3610 he couldnít tell me
    Dad lived till he was 89 and drove and took care of his tractor up until his last 9 months. Now I have to add hydraulic fluid and I want to be sure this is the right place. Is the bolt in the center of the pic the place to add the fluid? It is behind and slightly to the right of the top link.-img_1067-jpg
    TXDon
  2. #2
    Join Date
    Jul 2003
    Posts
    11,062
    Central Texas
    What fluid goes in the filler cap right in front of the gear shifters?-img_1063-jpg
    TXDon
  3. #3
    Join Date
    Jan 2011
    Posts
    710
    Westmoreland County PA
    Fords
    Default Re: DadÁóī Ford 3610 he couldnÁ®ö tell me
    The one in the front is for the transmission (check it with the dipstick shown in your picture). The plug on the rear housing is where you would fill your hydraulic fluid (the fluid is shared between the hydraulics and the rear axle housing). There is a check plug for the level of the rear housing, rather than a dip stick. I believe the plug is an internal hex (allen). It is just below the hydraulic pump, which near the back of your right foot when driving the tractor.
    UTF with a 134 spec is recommended for both compartments. Do not use "regular" hydraulic fluid. 134 spec UTF is not hard to find. I just bought 20 gallons of it at TSC for around $25 per bucket on sale (Traviller brand).
  4. #4
    Join Date
    Jul 2003
    Posts
    11,062
    Central Texas
    Default Re: Dadís Ford 3610 he couldnít tell me
    Thanks Strum456.
    Is this the right one on the left for both places-img_1070-jpg
    TXDon
  5. #5
    Join Date
    Jan 2011
    Posts
    710
    Fords
    That looks like it. Look on the back under Ford. It should list 134a, b, c
  6. #6
    Join Date
    Jul 2003
    Posts
    11,062
    Central Texas
    Quote Originally Posted by strum456 View Post
    I will, thanks.
    I also noticed he had some 90wt oil. Would that be used anywhere on the tractor. I know on my kubota I use it in the 4WD front axel, but this tractor is only 2WD.
    I did find the engine oil dipstick and where to add oil on the opposite side. Yea!
    TXDon
  7. #7
    Join Date
    Jan 2011
    Posts
    710
    Fords
    Quote Originally Posted by txdon View Post
    I will, thanks.
    I don't think so. Does it have manual or power steering? If manual, the steering box might take 90wt. If power steering, then you can just use the same fluid in everything except the engine.
  8. #8
    Join Date
    Jul 2003
    Posts
    11,062
    Central Texas
    I forgot about the power steering. I do remember he said it was power steering. I need to locate where the fill cap is for it.
    TXDon
  9. #9
    Veteran Member flyerdan's Avatar
    Join Date
    Aug 2011
    Posts
    1,245
    Salem, OR
    Hyster H50 Bobcat M700
    Have a look at this and see if it's close enough to be of any help.
    Whoever said that you can't fight city hall had obviously never met Marvin Heemeyer.
  10. #10
    Join Date
    Jul 2003
    Posts
    11,062
    Central Texas
    Quote Originally Posted by flyerdan View Post
    It does a little, thanks. I think his is about 10 years older, I'm going to have to find out when he bought it.
    TXDon
Similar Threads
  1. Need help with Dad's tractor - Ford 3610
    By txdon in forum Parts/Repairs
    Last Post: 08-23-2016, 06:07 PM
  2. Ford 3610 not starting
    By Ford3610 in forum Parts/Repairs
    Last Post: 04-06-2014, 05:02 PM
  3. Ford 3610 w/aftermarket loader
    By Zym in forum New Holland Owning/Operating
    Last Post: 11-01-2011, 01:52 PM
  4. Ford 3610 Not Charging
    By firefighter9208 in forum New Holland Owning/Operating
    Last Post: 04-03-2009, 10:18 AM
  5. Ford 3610 Handbrake
    By mikadams in forum Parts/Repairs
    Last Post: 10-22-2004, 08:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
