From my most helpful thread list:
#6. Sticky/sluggish hydro pedals
HST Just Won't Stop, Quit, Woah! In this post, Spencer200 gives the part number for a new spring and plate for the Class II and Class III Boomers. Older models have a weaker spring, the newer DA models should have the stronger spring already. Even so, the thread makes good (?) reading.
There is some "reluctance" for the hydro pedal to return to neutral, and this is intrinsic to hydrostatic transmissions. This "reluctance" is overcome with a spring attached to the hydrostatic plate. This spring is under the right side drivers platform, and is indicated in the attachment. You can adjust the spring to exert more tension on the plate to have it return to neutral. Also, make sure the roller is well lubricated.
Also, this "sticky pedal" is made worse by having a heavy load at low RPM. The lower RPM decreases the internal transmission "Charge Pressure", making the hydro respond sluggishly. Run the tractor at rated speed (2400 - 2600 rpm) to keep the charge pressure up to help with this.
Running at 2600 RPM, with a new spring and a greased roller, the tractor should stop quite suddenly if you quickly remove your foot from the forward pedal. Most people adjust, and even get used to not using the brakes to stop.
I'm sure with a little experience it will all come naturally.
