GATC35
Gold Member
- Joined
- Oct 5, 2004
- Messages
- 329
- Tractor
- New Holland TC-45D
This afternoon while pushing brush up into a pile I had a little accident with my 2003 TC-35D. A three inch tree limb came into the left side of engine compartment and did some minor damage. It pushed the two hydraulic lines that run to the hydraulic oil cooler up into the fan shroud. This of course distorted the shroud and caused several fan blades to break. It also broke the lower attachment off of the shroud that protects the muffler / exhaust system. After removing the limb I was able to pry the hydraulic lines down enough to get the tractor running and back to the barn. I was lucky because I have no radiator damage and loss no hydraulic fluid. The thing that is so odd the limb hit dead center of the bracket that supports the hydraulic lines and exhaust system shroud. The bracket was not attached to the frame at all. There is a hole in the bracket and a threaded hole in the frame but no bolt. At first I thought the bolt sheared off. After a closer look the paint on the bracket, and inside the threaded hole, was not scratched or worn. The complete area showed dirt, grease, mud, etc. with no sign a bolt had ever been installed. /forums/images/graemlins/mad.gif I would take some pictures but the kids are using the digital camera for a school project.
So could one of you nice TC-35/40/45D owners take a peek at this bracket and see if it is bolted to the frame ? When you open the hood the bracket is right under the lower radiator hose, and directly above the front axle.
I believe all I will need to be back up and running is the fan and exhaust system shroud. It could have been allot worse.
Thanks.....
Thanks.....
