JASTN70D
Gold Member
I have had some time and great help this winter to make some what I believe much needed modifications to the TN. The first is a combination project of adding a diverter valve to enable front mount hydraulic equipment use I.E in my case a grapple.
It required a mount of the valve and a re plumb so while I was at it I moved the FEL Quick Connects out from under the tractor to the side. I had a number of problems with the way NH mounted the QC. First the QC's were so close together you could not get your hands on them had to use a tool to push in the QC. Second It was a pain to lay under the tractor to connect/disconnect. Third I have had a number of instances where some rouge brush has disconnected the FEL for me. (Strange when things just quite working) So here is my solution
Pics to follow
Pics to follow
