Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Join Date
    May 2005
    Posts
    32
    Northwest Kentucky
    NH TC24DA
    Default Re: Trailering questions
    Thanks for the pics! That setup looks about like what I need. I'll be hauling other things than my tractor from time to time, so the more tiedowns the better. Those stake pockets sound OK, too.
    Soundguy, those stops of yours are exactly what I dread! [img]/forums/images/graemlins/blush.gif[/img]
  2. #12
    Join Date
    May 2005
    Posts
    32
    Northwest Kentucky
    NH TC24DA
    Hey, guys, while we're kicking the can...do these trailers do OK in outside storage, or are they better off garaged? I won't be hauling stuff very often so it would be sitting out in the elements for fairly long periods at a time. Considering that The Boss says I can't have an equipment shed for a few years yet, should I consider some sort of rental storage joint or will I be OK just leaving it in the back 40?
  3. #13
    Super Member Bob_Skurka's Avatar
    Join Date
    Jul 2003
    Posts
    7,503
    My trailer sits outside.
    I do tend to touch up the rust spots every now and again to keep the rust down. While there are a couple high quality trailer brands out there, MOST trailers are not very well built, the paint is not up to the standards of what you'd find on a car! Most get a simply spray coat of paint and not much else before you take them home.
  4. #14
    Join Date
    Nov 2003
    Posts
    1,407
    monroe michigan, barton city soon
    NH TC 35 had, now a TC35DA LS25 lawnmower
    KY; I leave my trailers outside year round. [img]/forums/images/graemlins/frown.gif[/img] My oldest one is a 2000 Haulmark enclosed. I don't have a big enough building to get my trucks inside, let alone a trailer. [img]/forums/images/graemlins/frown.gif[/img] Now my TC, does get a house in the winter. [img]/forums/images/graemlins/grin.gif[/img] One of these days........
    [img]/forums/images/graemlins/grin.gif[/img] [img]/forums/images/graemlins/grin.gif[/img]
    I've not had any problems caused by weather yet.
  5. #15
    Join Date
    Mar 2004
    Posts
    599
    western WA
    sold PT-425
    </font><font color="blue" class="small">( While there are a couple high quality trailer brands out there, MOST trailers are not very well built )</font>
    For sure, Bob's right on the mark. Our new Haulmark enclosed race car hauler came with "ventilated" wheel box corner welds--Swiss cheese holes big enough to see daylight and let rain inside, too. Also, rear ramp door is mis-aligned. Right side is full 1.5 inches higher than left. Our dealer is great, and she took care of the welds. At the end of the season, they will send trailer back to Haulmark to fix the door (under warranty). So, given the quality control issues with most trailers, if you are buying new, make sure you hook up with a reputable dealer who is willing to work with the manufacturer on your behalf.
    Another observation from the school of hard knocks is that the most durable trailers are the all aluminum ones. Livestock haulers must know something. Around here, they mostly use Featherlite {HERE}
    We have a Featherlite dual axle open hauler, and it's the best made trailer we've had. Moreover it is LIGHT. Did I say light? That means you can have a bigger payload w/o exceeding the GVWR for the trailer+payload+vehicle.
    Outside storage is pretty much the norm. The only maintenance item I would underscore is the importance of re-packing the wheel bearings once a year (or every ~15K miles if you do a lot of hauling). Some of the higher end units have lifetime bearings, meaning no repacking. Others have "EZ lube" bearings with a Zerk fitting. Just pump your grease gun until you see you've replaced old stuff with new. Makes a messy job pretty tolerable.
    That's my $0.02...
  6. #16
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    </font><font color="blue" class="small">( do these trailers do OK in outside storage, or are they better off garaged )</font>
    My wood deck 16' trailer has been setting outside since 2001. I put a new deck on it in 2002 as the deck from the factory ( 2000 ) had a few bad boards.. and looke dlike whitewood spruce not PT!!
    The pt boards I put on have shown no signs of decay yey.. however I did put 2 coats of asphalt fence paint on it as soon as I decked it.
    Soundguy
  7. #17
    Join Date
    Jun 2003
    Posts
    117
    Upstate NY
    TC40D
    As I understand it here in NY using the stakepockets for anchor points is a no no. My trailer has D rings on each corner and two in the middle. I usually run a chain through the front bumper to the front corners and one over-center binder there, then put a clevis on the draw bar and run a chain through that to the rear corners and another chain binder there. If I have something on the three point hitch, I run a two inch strap (avioding sharp edges or a peice of thick rubber in between) or another chain and binder over the attachment also. The truck drivers at our dealership haul equipment this way and haven't had a problem losing anything or any problems with DOT either. There are many ways to haul equipment and how to secure it, but the safest way is the best. Always think, "it may be someone you know or love that may get hurt or worse if that peice of equipment comes loose".
  8. #18
    Veteran Member GeneD14's Avatar
    Join Date
    Jul 2003
    Posts
    1,311
    Tennessee
    Kubota M95s, Allis Chalmers 185 & D17 series IV, Kubota ZG-23 Mower, Kawasaki Mule 610
    My tractor didn't have a good place to chain it down to so I added these bolt on hooks.
    Attached Images Attached Images
  9. #19
    Join Date
    Jul 2003
    Posts
    1,311
    Tennessee
    I would also recommend welding on D-rings if your trailer doesn't already have them. It only takes a few minutes to weld on heavy duty ones like these that you can buy at TSC.
  10. #20
    Veteran Member RedRocker's Avatar
    Join Date
    Apr 2004
    Posts
    2,118
    Bowie TX
    Kioti CK30 HST, dual remotes, FEL.
    </font><font color="blue" class="small">( My tractor didn't have a good place to chain it down to so I added these bolt on hooks. )</font>
    I did the same thing Gene, makes it pretty quick to chain down.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
