ohdeerfarmer
Member
I took delivery of my TC24DA on 6/22/05 and so far have managed to get only 18 hours on it, mostly using the FEL to move gravel, dirt, much and compost. The FEL (12LA) is working great and with a 54" bucket I have heaped wet #411 (limestone chips & dust) and moved it without any hesitation!
So far this tractor ROCKS! I love the power steering, HST, power, fuel consumption and ease of use.
At the moment she has a hose leak below the quick disconnects on the rubber hose side. It is NOT the connector but the hoses between the bend in the hose and the crimp, the hose looks "stressed" and is cracking on the two hoses with 45 degree bend connectors. I spoke to the dealer and he said they would repair or replace the hoses but I'm affraid this will keep happening due to hose configuration. I went back thru this site and looked at a couple of pics some of you guys have with respect to hose mounting location on the FEL (12LA). From these photos it appears my FEL is plumbed differently but when I go back to the manuals I can't find any pictures or info on how the hoses should be attached. The dealer also claims the hoses are mounted properly.
There are disconnects in a row (blue green yellow & red , I think is the config?) vertically (I'm thinking the hoses were swapped and mounted wrong by the installing dealer).
Do the 45 degree bend hoses go on top and the 90 degrees go on the bottom?
I'm also having a problem with the hoses rubbing the front tire when turning. The hose is behind the bracket but it seems to be slightly too long......again I think they installed the pair incorrectly but the manual does not help with this either?!?!
Any Thoughts or Suggestions?
