Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Aug 2005
    Posts
    7
    Bushnell, Florida
    NH 1715 & JD 4120
    Default 1715 4wd needs new tires
    Hello. My 1715 4wd is in need of some new tires. It currently has AG tires on it an I am wondering if I can replace them with something less aggressive without switching out the rims or causing ratio problems between the front and rear. Any suggestions? thanks Jim
  2. #2
    Join Date
    Apr 2005
    Posts
    50
    Default Re: 1715 4wd needs new tires
    I'm on expert but I know that on my Uncles 2120 with turf tires, we called to see if we could switch to ag tires and they said we would definately need to change the rims to make the ratio right.
  3. #3
    New Member
    Join Date
    Jul 2003
    Posts
    6
    Iuka, WV
    TC-29D
    If you have any hills you might want to at least use ags in the back. My tractor has loaded r4's and wants to slide downhill sideways.
  4. #4
    Join Date
    Feb 2001
    Posts
    1,447
    South-central Michigan
    New Holland TC40D
    Jim, I think you hit upon both issues with going to anything different. However, you might be able to find something that fits your existing rims, and still is considered an ag tire, but looks a lot more like a industrial. Find a good Firestone or Goodyear tractor tire dealer, or thoroughly search their websites. You may just find a good comprimise.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
