Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
  1. #11
    Gold Member Roto's Avatar
    Join Date
    Jul 2003
    Posts
    382
    Mid Maine
    TC55DA and TC33D
    Default Re: TC33D Glow Plug Timer
    I just put new ignition switch on because that too was screwed up and started turning real hard. It wasnt that. Im getting the relay and hope it works. Thanks!
    mike
    NH TC55DA EHSS with 270TL loader and 759C BH and TC33D with 7308 loader. Attachments include; mower, tiller, box scraper, forks, spreaders, all hay equipment and more... Over 120 tires that require air.
  2. #12
    Super Member
    Join Date
    Oct 2003
    Posts
    7,345
    Northeast, Ohio
    TC-40D SS New Holland
    I would think it an easy task to pull the timer and bench check it. I have what I believe to be a timer on its way out and that's how I'll determine which part actually needs replaced.
    I can't imagine these timers to be all that different from model to model. I can supply the test proceedure if you need it.
  3. #13
    Elite Member
    Join Date
    Mar 2006
    Posts
    3,059
    Wisconsin
    2003 NH TN70A
    Quote Originally Posted by PineRidge
    Supply it!!!!!!!!!!!!!
    Thanks, Bob
  4. #14
    Join Date
    Sep 2003
    Posts
    541
    Brookeville, MD
    TC33D
    Yes, itís probably worth a try, unless the problem is intermittent, as mine was.
  5. #15
    Super Member
    Join Date
    Oct 2003
    Posts
    7,345
    Northeast, Ohio
    This covers the Class IIIs, see if it will apply to your timer.
    Attached Images Attached Images
  6. #16
    Join Date
    Jul 2003
    Posts
    382
    Mid Maine
    TC55DA and TC33D
    I ordered the glow plug timer and got it here. I ordered the part number listed here. I was expecting something else even though it may be what i need. I was looking on my tractor behind fuse panel with side cover off there a 3 or 4 black square 1" by 1" plugs that just plug into a board. they are all right in a row. one of them clicks when my glow light comes off and on so i thought that was it. On my tractor is said Bosch. the part i got is a little bigger and says NGK and doesnt plug into that spot that i thought so where does it go? Whats the scoop? 2003 Tc 33D
    Mike
  7. #17
    Super Member
    Join Date
    Oct 2003
    Posts
    7,345
    Northeast, Ohio
    Sounds to me like you may have purchased one of the relays instead of the timer.
  8. #18
    Gold Member
    Join Date
    Nov 2004
    Posts
    250
    Kansas City, Kansas
    BX2370 Kubota, Ford 1100, MF135
    The inch by inch Bosch black "plug in thing" you are refering to is your relay. It should have the amps stamped on the top of it. i am thinking the timer is rectangled shaped but could be wrong.
    Quote Originally Posted by Roto
    My light is screwed up and im thinking of getting this timer(relay)(controller)(whatever) is it the the bosch plug in thing thats about 1" by1" and just plugs in? Thats what i hear clicking on mine and glow light does not stay on long enough now and random comes on and off.
    Mike
  9. #19
    Join Date
    Jul 2003
    Posts
    382
    Mid Maine
    TC55DA and TC33D
    Well i put the glow timer in and it seems to work. I need more time to really see if that was the problem but so far it seems that was it. that bosch thing was doing all the clicking so i thought that was it but evidentally not. the timer must have made it click. thanks for all the info.
    Mike
  10. #20
    Join Date
    Sep 2003
    Posts
    541
    Brookeville, MD
    TC33D
    I had a time getting the dealer to order the right part. I'm pretty sure the part number I posted is correct. I think maybe they changed suppliers.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
