Results 1 to 3 of 3
  1. #1
    Gold Member
    Join Date
    Jan 2001
    Posts
    381
    Southern York County, ME
    TC 21D & Farmall 100
    Default 3 point hitch slowly creeps down
    I recently added about 300 pounds of weight as ballast to my 3 point hitch. I made a box filled with concrete. My problem is, that after a few days the weight and the 3 pt slowly works it's way all the way down. Is this normal, after not running the tractor for several days? Is something defective or is this a common problem? This probably has been discussed before, but any help would be appreciated. My tractor is a NH TC 21 D.
  2. #2
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    35,101
    Texas
    Default Re: 3 point hitch slowly creeps down
    banjobj, I don't think it's unusual for it to slowly bleed down; however, I just wouldn't ever leave it parked with a weight on the 3-point raised. I always lower any implement or weight on the back (and the front end loader if it's on the tractor) when I park the tractor. In my opinion, to do otherwise is just putting an unnecessary strain on valves and seals.
    Bird
  3. #3
    Gold Member
    Join Date
    Jan 2001
    Posts
    381
    Bird, Thanks for the reply. I only left it up a couple of times and the way I built the weight box it is only about 8 or 10 inches off the ground. I Make it a point to remove weight now, especially since it seems to creep down. I always park with the FEL lowered to a wooden pallet. I respect and appreciate your opinions.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
