Hi Guys,
Just thought I would give you a little update. I stopped at my Case dealer last week and spoke to my parts guys. He was able to look up the schematic of the steering column and “explode” the image to find my missing bolt. He was also able to tell me that it is an 8M x 12 metric and an 8.8grade (I believe). It is also a set screw style with an allen-head to fit in the recessed hole in the collar plate that holds the top of the tilt strut.
Anyhow, he recommended a trip to our local HWI hardware because this is obviously not something they carry in stock. The closest thing I was able to find was an 8M x 20 so I brought it home and thought if it was too long I would cut it off and grind it down. After a test run, I found that not only was it too long, but the head was also too big to fit in the recess hole. I then called my parts guy back and he ordered me one. He ordered it on their normal stock order (NO sense in paying $10++ for overnight shipping on a $.75 bolt) and I should have it next week. Anyhow, the tilt steering is still working for now, it is just a little sloppy.
Also, I wanted to say THANKS for all of the posts and pictures about the “captive nut” repair. I took some time last weekend and used the two-part epoxy you all mentioned. I got the shrouds put back together and SO-FAR-SO-GOOD.
FYI: I also got some great seat time yesterday. We received about 12 inches of snow and a lot of wind over the past few days. The tractor got a good workout yesterday clearing all of the white stuff. Thankfully, it was clam, sunny and a balmy 15 degrees.
Thanks again for the help!
CBox
