I would like to thank all of you for your help, but please don't go away, I have a few more questions.
First thing, the valves on my 2910 control the following if I have my gannon attached:
1) Raising and lowering the lift arms (if that's their proper name?)
2) Side sway tilt for my gannon, where you can raise one side higher than the other. (Photo does not reflect attached gannon)
3) Lastly, the cylinder tilts the gannon forward and backward.
Okay, as far as connecting my backhoe, here is what I think I have learned:
I can use the freed up valve with a bungie cord and have one valve remain open so that I have fluid flowing to the backhoe.
I also understand I can use the same size connections that I currently have on my tractor to hook up the backhoe.
1)
The backhoe comes with a larger connection, so my next step would be to replace the larger male connectors (and hoses) on the backhoe with the same size connectors (and hoses?) that I have on the tractor, correct?
2) This is a very old backhoe attachment, should I replace the hydraulic lines?
3) The cylinder on my tractor will be removed so that I can rigidly install the backhoe. This is an old backhoe that I just purchased and I expect to have things to repair or replace. Any other safety issues that I should be concerned with?
4) As soon as I have the opportunity, should I build (or buy) a rigid sub-frame for my tractor or in your opinion is my tractor "beefy" enough to handle the stress? Where I live, we have heavy clay soil. When its wet, you sink up to your a**, when its dry, it as hard as concrete.
5) RickB, What does putting the draft control fully "in position" mean? Yeah, I know, novice!
Note: The backhoe is an Arps model 728.
Thank you again for all of your input.
Rick
