y
making a large lawn roller
   / making a large lawn roller #1
doverking
dover,me
jd 1070
Hi I'm new to the forum and I know I'm not the first one to ever need a large lawn roller. I'd like to get suggestions on making one at home. Happy trails and thanks to all. Mark
   / making a large lawn roller #2
Welcome,
Towed or 3-point?
Bruce
   / making a large lawn roller #3
It's been suggested (and I have considered) using an old propane tank.
   / making a large lawn roller #4
I picked ours up along the road a few years ago. It appears to have been a propane or water tank with the ends cut off, and filled with concrete except for a central core/axle composed of a 1.5" steel or black iron pipe. It weighs a couple of hundred pounds and is pulled by a frame of galvanized pipe that extends through the center to a handle like one of the really simple simple wire cheese slicers, like an inverted "Y".
We hook it to our tractor using a trailer hitch accessory that has a clevis on it, and it works pretty well on fresh gravel or softish ground. It does scuff a bit pn turns, but seems none the worse for the wear from it, and it doesn't seem to damage the grass.
Thomas
PS: Welcome to TBN!
   / making a large lawn roller #6
i made mine out of 55 gallon plastic drum,worked great pull behind lawn tractor.
   / making a large lawn roller #7
My first one was made from an old brine tank, 36" diameter x 7' long. I finally got tired of patching the rusty hulk and built a new one.
The old frame was re-used as was the axle and bearings. I made my own tank using a chunk of 30" dia x 1/2 wall steel pipe and purchased tank heads for the ends.
I've got 3 springtimes of use on it so far, couldn't be happier with it.
Ed
Thanks forThe Great Reply!
Where Did You Get The Ends And Do You Fill It With Anything FoR Weight?
Great Hey Thomas, Thanks For Your Great Ideas.Glad To Be A member.
   / making a large lawn roller #10
Got the heads from these guys. Tank Heads | Pressure Vessel Heads | Home | Commercial Metal Forming Good people to deal with, just remember they will probably ship truck freight. IIRC, the ones I got were 3/16" thick.
Yes, I fill it with water.
On a roller this big/heavy the shaft for the bearings needs to go all the way through the roller
Ed
Thanks Ed, Great information! I do appreciate it. Mark
Thanks for your time Bruce, I'm looking to pull the roller behind my tractor
Peterbilt 377 Semi-Truck (A61306)
Peterbilt 377...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
UNUSED RAYTREE RMDM72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2002 Miller Trailblazer 301G Towable Welder Generator (A59228)
2002 Miller...
