Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Elite Member
    Join Date
    Oct 2004
    Posts
    2,952
    limerick pa lycoming county pa
    kubota bx23
    Default mobile application
    mobile app for kindle i cant find one and search for"app" strikes out.
    If it ain't broke we will help you brake it
    If it is broke we will help you get it fixed!
    https://www.facebook.com/joseph.t.mussington
  2. #2
    Join Date
    Feb 2012
    Posts
    732
    Germanton, NC
    Kubota MX5100F IH McCormick Farmall 140, Massey Ferguson 135
    Default Re: mobile application
    I had the iPad app and it lost functionality after it updated. I connect via Safari on the iPad rather than the app.
  3. #3
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Quote Originally Posted by tommu56 View Post
    If your speaking of the new Kindle fire. I understand it has to be rooted in order to run Android apps other than the media apps they want you to use. It would be like jailbraking the iOS. Pity it won't run Google apps. But that's a marketing tactic. -kid
  4. #4
    Elite Member
    Join Date
    Oct 2004
    Posts
    2,952
    kubota bx23
    Tapatalk works for my other forums but I couldn't get it to hook up with TBN
    Tapatalk
  5. #5
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    Default
    Tapatalk
    The new Google pad looks like the way to go. I'm just a bit Leary though. Google knows more about us than the CIA already.
  6. #6
    Elite Member
    Join Date
    Oct 2004
    Posts
    2,952
    kubota bx23
    Bump is one available yet I had knee surgery and can't get to my computer.
    Will tractorbynet work on tapatalk?
    TOM
  7. #7
    Join Date
    Nov 2012
    Posts
    1,479
    Hawthorne, FL
    Kubota L285
    Default
    I use the TBN app in my android phone, don't think ive really ever logged on TBN with computer.
  8. #8
    Elite Member
    Join Date
    Oct 2004
    Posts
    2,952
    kubota bx23
    Quote Originally Posted by paulharvey View Post
    I wasn't clear I need it for a Kindle not my phone.
    tom
  9. #9
    Elite Member
    Join Date
    Oct 2004
    Posts
    2,952
    kubota bx23
    Here is an up date there is a way to add apps (I've done 2 so so far) on kindle fire hd.
    You have to have android phone or have source for the app (xxxx.APK file)you want.
    and a computer and cables to move the files from phone to kindle
    Down load es file explore app to the phone and to kindle fire.
    link to es file explorer
    down load the app you want to phone and make sure it works.
    mobile application-phoneshot1_zpsde5d4f97-jpg
    On phone go in to es file explorer
    menu key
    app manager
    user apps
    mobile application-phoneshot2_zpsf353eece-jpg
    select app you want to move to fire (it will be highlighted)
    on soft keys at bottom select back up
    Then connect computer to phone navigate to backups on phone.
    mobile application-phonescreencomputer_zps30a68981-jpg
    Copy file to your computer (remember were you put it)
    Unhook phone hook up kindle
    Go to file es file explorer and back up any app the same as on phone
    (this will make back up directory's)
    On computer navigate to app that you saved to it and copy and paste it to back up folder on
    mobile application-kindlebackupshotcomputer_zps3379d9f2-jpg
    Unhook kindle
    On kindle go to es file explorer and navigate to backup/apps and click on app file you just put there it should pop up install or re install, say ok and let it install
    log in to TBN app and give it a whirl!
    Tom
  10. #10
    Silver Member Cpjlube's Avatar
    Join Date
    Sep 2010
    Posts
    244
    Champaign County, Ohio
    Case ih 254
    Default
    Here is an up date there is a way to add apps (I've done 2 so so far) on kindle fire hd. You have to have android phone or have source for the app (xxxx.APK file)you want. and a computer and cables to move the files from phone to kindle Down load es file explore app to the phone and to kindle fire. link to es file explorer down load the app you want to phone and make sure it works. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348657"/> On phone go in to es file explorer menu key app manager user apps <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348658"/> select app you want to move to fire (it will be highlighted) on soft keys at bottom select back up Then connect computer to phone navigate to backups on phone. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348659"/> Copy file to your computer (remember were you put it) Unhook phone hook up kindle Go to file es file explorer and back up any app the same as on phone (this will make back up directory's) On computer navigate to app that you saved to it and copy and paste it to back up folder on <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348660"/> Unhook kindle On kindle go to es file explorer and navigate to backup/apps and click on app file you just put there it should pop up install or re install, say ok and let it install log in to TBN app and give it a whirl! Tom
    Is there a way to get the .apk file without an android phone? I have a kindle fire but no other android devices.
    Chuck
    Chuck
Similar Threads
  1. Iphone application
    By czechsonofagun in forum Related Topics
    Last Post: 12-02-2011, 10:28 PM
  2. gck60-bx application
    By Woodsmoker in forum Kubota Lawn & Garden
    Last Post: 06-17-2010, 12:46 PM
  3. Is this an application for a mulcher?
    By Barton in forum Land Clearing Equipment
    Last Post: 06-02-2009, 08:36 AM
  4. API GL-5 in GL-4 application
    By reb in forum Oil, Fuel & Lubricants
    Last Post: 09-04-2005, 02:39 PM
  5. compost application
    By Garrabo in forum Kubota Owning/Operating
    Last Post: 08-03-2004, 08:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
