Results 1 to 9 of 9
  1. #1
    Veteran Member deepNdirt's Avatar
    Join Date
    Sep 2009
    Posts
    2,301
    Nth East Ga, USA
    yanmar YM-1700
    Default Why when typing the cursor hangs up?
    As most of you who read my post know I'm kinda Long winded , in most of my post or threads I try my best to make my writing easy on the eyeballs, But when I try to space the paragraph's the cursor hangs in the same line, it doesn't move down when I hit enter key, so that I can start a new paragraph, I wind up writing the entire post with everything pushed together, I'll then go ahead and submit the post, come back and edit it, It is only then when I edit it I can space the paragraphs, It does allow me to space the words though, there is another issue that happens when I come back to edit it, Sentences become duplicated on it's own, I now have to back up and remove duplicates, anyone else having this problem? even with this very post you can see that It didn't allow spacing paragraph's, the cursor simply doesn't drop down, its not the enter key because I can write emails and on other forums with no problems, and oh! and at times the cursor will hang up in one spot, I'll have to hit the space bar several times to get it to move, and when it does it moves the amount of times I previously hit the bar,
    Never judge a man until you've walked a day in his shoes,
  2. #2
    Join Date
    Jun 2011
    Posts
    2,323
    CNH 4020
    Default Re: Why when typing the cursor hangs up?
    Quote Originally Posted by deepNdirt View Post
    As most Know of you who read my post you know I'm kinda Long winded , in most of my post or threads I try my best to make my writing easy on the eyeballs, But when I try to space the paragraph's the cursor hangs in the same line, it doesn't move down when I hit enter key, so that I can start a new paragraph, I wind up writing the entire post with everything pushed together, I'll then go ahead and submit the post, come back and edit it, It is only then when I edit it I can space the paragraphs, It does allow me to space the words though, there is another issue that happens when I come back to edit it, Sentences become duplicated on it's own, I now have to back up and remove duplicates, anyone else having this problem? even with this very post you can see that It didn't allow spacing paragraph's, the cursor simply doesn't drop down, its not the enter key because I can write emails and on other forums with no problems, and oh! and at times the cursor will hang up in one spot, I'll have to hit the space bar several times to get it to move, and when it does it moves the amount of times I previously hit the bar,
    If you haven't already, try opening ( maximizing ) the window when you are typing.
    I have experienced the problem you describe when posting on this site and opening up the window fixes it for me.
    Ron
  3. #3
    Elite Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    4,027
    SW VA
    Kubota 9540, RTV 900 and David Brown 885.
    Long winded for sure, I only count two sentences.
  4. #4
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,750
    Westminster, MD
    John Deere 4110, 455AWS
    Known problem with IE 10 and the vBulliten software used to run the forums. Click the broken page looking icon on the toolbar and you return key should start working again. Or use FF or Chrome...
    KennyD
    www.boltonhooks.com
    #BoltOnHooks
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  5. #5
    Join Date
    Sep 2009
    Posts
    2,301
    Nth East Ga, USA
    yanmar YM-1700
    Quote Originally Posted by DT86 View Post
    My point exactly , I didn't bother to edit it in order to show how it comes out while I'm typing,
    and you didn't have to jump so quick to agree with me being long winded
    Thanks!
    Pacerron & kennyd for the tips
  6. #6
    Silver Member daveshoot's Avatar
    Join Date
    May 2010
    Posts
    226
    Southern CA
    B2320, X300
    Could be account settings. In your profile, under general settings, Miscellaneous, you can check this...
    Why when typing the cursor hangs up?-setttings-png
    B2320, FEL, box scraper, KK rear rotary mower, JD X300 mower
  7. #7
    Veteran Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    I have never had that problem using Firefox.
    Perhaps I get too many paragraphs.
  8. #8
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    6,737
    Meridian, OK
    Bobcat V417 Toolcat 5610 F TORO+Loader
    Not happening on Windows XP and Chrome.
    I received a tip a long time ago, that makes things gooder , so I will pass it forward.
    When you want to reply or post a new thread, double click and it puts you in the advanced mode.
    Try it you'll like it!
  9. #9
    Join Date
    Sep 2009
    Posts
    2,301
    Nth East Ga, USA
    yanmar YM-1700
    Alright!
    Big Thanks Guy's, daveshoot
    it seems to be working correctly now,
    what I did was to go and change
    in the settings under Miscellaneous Options,
    I changed it from Enhanced Interface
    to Standard Editor, Happy!
    and to think all the while
    I've been doing it the hard way,
    Attached Thumbnails Attached Thumbnails Why when typing the cursor hangs up?-settings-png   Why when typing the cursor hangs up?-settings-2-png
Similar Threads
  1. HST pedal hangs
    By jruss in forum Kubota Owning/Operating
    Last Post: 12-13-2007, 12:51 AM
  2. MOWER THAT HANGS OFF THE SIDE OF TRACTOR??
    By JHFV in forum Attachments
    Last Post: 06-10-2006, 09:07 PM
  3. Who hangs out here, anyways?
    By daTeacha in forum Case-IH
    Last Post: 04-05-2006, 10:10 PM
  4. Mowing mower deck hangs low
    By gysurshot in forum Cub Cadet Tractors
    Last Post: 08-22-2005, 02:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
