Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > New Holland/Ford > NH Buying/Pricing
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Trackback Thread Tools Search this Thread Display Modes
Old 05-06-2008, 12:44 PM   #31 (permalink)
randy41
Default Re: Ford 1710 Injector Pump oil Problems
on my 1710 its a one piece filter..and its in a different place than the owners manual shows it to be.
randy41 is offline   Reply With Quote
Old 05-06-2008, 01:03 PM   #32 (permalink)
asylum
Member
Good, then mine is not the only different one.
asylum is offline   Reply With Quote
Old 05-06-2008, 07:42 PM   #33 (permalink)
dqdave1
When you get the filter at CNH dealer; get the needed gasket for the leak also. I would use nh134 hydro oil.
__________________
dqdave1; tc-29D; woods 7500 bh; 7308 fel, land pride tiller, land pride rake, gill pulverizer, 60"mmm. , bucket forks , MZ16H
dqdave1 is offline   Reply With Quote
Old 05-06-2008, 08:08 PM   #34 (permalink)
asylum
Member
Yes, that gasket needs to be replaced. Will do that when I drain the oil.
Where do I drain the front axle? I see it is just little over 2 quarts of 80 weight.
Old 05-06-2008, 08:41 PM   #35 (permalink)
randy41
asylum-I got a complete repair manual for my 1710. some of the pictures aren't real clear but its better than nothing. its useful.
Old 05-10-2008, 06:28 PM   #36 (permalink)
cbumdumb
New Member
I am going only by memory it has been awhile.
It has been a good 10 yrs since I worked for Ford/ New Holland the metering pumps that were lubed by engine oil are splash lubed by the gear train with a small resevoir around the bottom of the governor assembly which holds a small amount of the old oil when when engine oil is drained . So in the book they want you to add a small amount of oil to flush out the trapped old oil in the pump into the crankcase while you are draining it . The it service manual is vague in some of their descriptions but still a very good manual . They also don't show all the year break changes that were done from year to year .
cbumdumb is offline   Reply With Quote
Old 05-10-2008, 08:22 PM   #37 (permalink)
JC-jetro
JC-jetro's Avatar
Bingo, that's make perfect sense. Where have you been ? Thanks for chiming in. welcome to TBN blue
JC,
__________________
Ford 1700, 60" Woods Rotary Cutter, home made 3-pt boom ,King Kutter( 5 ft Tiller,Middle Buster,Single Row Cultivator,Carry All and 30" Dirt Scoop).
JC-jetro is offline   Reply With Quote
Old 05-10-2008, 10:43 PM   #38 (permalink)
cbumdumb
New Member
Lurking
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
Page generated in 0.13193 seconds with 11 queries
