Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > New Holland/Ford > NH Buying/Pricing
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-24-2008, 09:05 PM   #1 (permalink)
New Member
Copperhead's Avatar
Default 2420 or TN70
Ok... just getting ready to acquire 40 acres next to my current property. Will total about 45 acres. It is primarily crop ground, rolling hills. Putting about 15 acres into pasture and then the rest will be used for alfalfa and crop. Won't be a lot of tillage at any one time. Primarily hay. Will rotate sections periodically into other crops then back to hay ground. Will be doing primarily small bales. Will do the tillage work with the tractor and get my neighbor to combine.
Got a TC33DA now and obviously need to trade up. Looking at the T2420 and TN70, cab models w/loaders.
Got my ideas on which would probably be better, but wanted to bounce it off of the other members here and see what would be the better overall choice, both from a cost standpoint as well as functionality. Would be open to other models as well. Don't have unlimited resources, but need to make the best choice.
Would appreciate feedback from others. Thanks!
Copperhead is offline   Reply With Quote
Old 05-25-2008, 08:47 AM   #2 (permalink)
Default Re: 2420 or TN70
A utility tractor (the TN) is SIGNIFICANTLY cheaper to run in the long run.
You can put much bigger implements on it (less time running overall) and the maintenance intervals are much longer. Most compact tractors have 300 hour maintenance intervals. The TN has 1200 hour intervals.
In the long haul, that's going to be a LOT less money.
BTW, the TN75 is the same tractor as the TN70 but with a turbo, so when you bog down.... Just a thought, prices should be similar.
LoneCowboy is offline   Reply With Quote
Old 05-25-2008, 09:19 AM   #3 (permalink)
New Member
Copperhead's Avatar
Thanks. I was siding that direction and appreciate the confirmation. Hadn't started talking with my dealer yet. I like to have more opinions than just a dealer!
Old 05-25-2008, 11:28 AM   #4 (permalink)
Agreed from top to bottom. A Class IV for these uses is a knife to a gunfight thing.
RickB is offline   Reply With Quote
Old 05-25-2008, 04:11 PM   #5 (permalink)
I just noticed you want to run hay with it. You do NOT want to run hay equipment on a compact tractor. It will literally beat it to death. It's not the HP, it's the gearing and drivetrain.
Put the TN and the 2420 next to each other, then walk around back and compare the size of the rear gearboxes.
You'll immediately see the difference
Old 05-25-2008, 08:54 PM   #6 (permalink)
dgl24087's Avatar
FYI: The TN70 is turbocharged as well.
dgl24087 is offline   Reply With Quote
Old 05-26-2008, 08:50 AM   #7 (permalink)
New Member
Copperhead's Avatar
Thanks for all the feedback! I was looking at PTO horsepower alone. I knew I could get some good feedback here to help the decision process.
Old 05-26-2008, 05:04 PM   #8 (permalink)
Quote:
really????????
oppps
Where do they sneak that 5 extra HP from then???????/
Old 05-26-2008, 09:48 PM   #9 (permalink)
dgl24087's Avatar
Just a guess, but I'd say more boost.
Old 05-27-2008, 04:54 AM   #10 (permalink)
Pick one with enough gears. I have the 8 spd (4x2) trans in my TN55. I haven't used it enough to worry about it (yet), but I will probably wish I had gotten one with another speed range. Still a lot more tractor than the TC line. 1/2 ton truck versus a 3/4 ton truck. And man is that cab sure nice!
mojoinco is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
