HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > New Holland/Ford > NH Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 04-17-2008, 01:59 PM   #1 (permalink)
New Member
Default 2120 Shuttle Shift question
Hi,
I have a new-to-me 2120 with the HSS transmission. When parked in gear on a slope, the tractor rolls as if it were in neutral or the clutch pedal were depressed. Otherwise, it operates as normal, with no signs of slipping, chattering, etc, even under hard use.
Any ideas? thanks!
finspop is offline   Reply With Quote
Old 04-17-2008, 09:04 PM   #2 (permalink)
Default Re: 2120 Shuttle Shift question
Quote:
Originally Posted by finspop
Hi,
Any ideas? thanks!
If you mean parked not running with the shuttle in F or R and both range and gear levers not in neutral, that's perfectly normal. The HSS drives through one of two hydraulic clutches (F or R) and either require hydraulic pressure and flow for lockup. Set the brakes before dismounting every time.
RickB is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
