HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > New Holland/Ford > NH Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Trackback Thread Tools Search this Thread Display Modes
Old 05-06-2008, 07:06 AM   #11 (permalink)
jinman
Super Member
jinman's Avatar
Default Re: TC35D Won't Start Need Help
Quote:
Originally Posted by dqdave1
Howdid you jumper the seat switch?
Dave, the seat switch just causes the fuel cutoff solenoid to de-energize. The starter will still work, but the engine will not start. The PTO lever and the transmission neutral switch are the things that will stop the engine from turning over. If the PTO light stays on and fuse #2 is good, then Bernie has a problem with his PTO switch. If the PTO light is off, then Bernie should check the connections to the transmission neutral switch under the left side of the operator's platform. Any additional troubleshooting requires taking off the cowling in front of the operator's platform to get to the ignition and relays.
__________________
Jim
jinman is offline   Reply With Quote
Old 05-06-2008, 08:54 AM   #12 (permalink)
BernieSr
New Member
BernieSr's Avatar
You can test the fuses from the top, they have a little hole in each side to insert the tester end in and that is what I did with a tester. Should I take them out and test them from the legs on each one and mostly the number two fuse.
Thanks,
Bernie
BernieSr is offline   Reply With Quote
Old 05-06-2008, 08:57 AM   #13 (permalink)
BernieSr
New Member
BernieSr's Avatar
To jump the seat switch I first took it apart and put a jumper wire across from side to side and after that didn't seem to work I used a tie wrap to hold the plunger down so I did have to be in the seat.
Thanks,
Bernie
Old 05-06-2008, 02:05 PM   #14 (permalink)
jinman
Super Member
jinman's Avatar
Quote:
Thanks,
Bernie
Bernie, I would pull the fuse and look at the filament. It's easy to see if it is burned out. However, if you turn on the key and the PTO light does not illuminate on the dash, then the fuse is probably okay. The problem with reading a fuse in a circuit is that it is much more difficult to do. If you read voltage across a good fuse, you will get zero volts. If you measure one side of a blown fuse to ground, it will be 12 volts and the other side may be 12 volts also even if the fuse is blown because there may be just enough resistance in the supply path to raise the open side to 12 volts as long as there is no more load than a tester draws. The safest way to read a fuse is to remove it and read for zero resistance leg-to-leg.
__________________
Jim
Old 05-06-2008, 07:24 PM   #15 (permalink)
dqdave1
Jinman; thanks for the explanation on the seat switch. I think he may want to see if he has voltage to the starter solenoid.
__________________
dqdave1; tc-29D; woods 7500 bh; 7308 fel, land pride tiller, land pride rake, gill pulverizer, 60"mmm. , bucket forks , MZ16H
dqdave1 is offline   Reply With Quote
Old 05-09-2008, 09:33 AM   #16 (permalink)
cleve34
New Member
Make sure your parking brake is on.
cleve34 is offline   Reply With Quote
Old 05-09-2008, 03:54 PM   #17 (permalink)
BernieSr
New Member
BernieSr's Avatar
Jim,
You were right it was fuse #2 after I changed it out the tractor started right up and ran perfect. I did put in a 10 amp one. Thanks for the help....
Bernie
Old 05-09-2008, 07:17 PM   #18 (permalink)
jinman
Super Member
jinman's Avatar
When I got home from work today, my tractor had the same problem. My wife had been using it. She went to start it and nuthin'. I got home and replaced the fuse to start the tractor. I'm going to look for that self-resetting CB because even though I know what the problem is, it's still a pain in the patoot to change it.
__________________
Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
Page generated in 0.14848 seconds with 10 queries
