HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > New Holland/Ford > NH Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-12-2008, 11:48 AM   #1 (permalink)
New Member
Default 1715 will not go into gear. clutch?
Hey, I am a new member and first time tractor owner.
I have a 1995 ford 1715 W/ bucket .
I was pushing A manure pile with the bucket and the tractor and it stopped.
It feels like it's in between gears I put the clutch in and can shift gears
but when I let out the clutch It tries to go Into gear and skips and starts to roll a couple inches and stops. Is this a clutch out or somthing shifted inbetween gears?
Thanks,
Ron
fishjett is offline   Reply With Quote
Old 06-12-2008, 12:31 PM   #2 (permalink)
JC-jetro's Avatar
Default Re: 1715 will not go into gear. clutch?
Thanks,
Ron
I had a situation like that with my 1700. I have both gear shifter and range shifter. The shifter was stuck in between the two gears. There is a detent ball and spring theta keep the shifter solidly where it need to be. Any how I ended up loosening the shifter bracket to position the detent ball correctly. Does your shifter moves freely? does it stay in intended position without jumping?
JC,
__________________
Ford 1700, 60" Woods Rotary Cutter, home made 3-pt boom ,King Kutter( 5 ft Tiller,Middle Buster,Single Row Cultivator,Carry All and 30" Dirt Scoop).
JC-jetro is offline   Reply With Quote
Old 06-12-2008, 02:18 PM   #3 (permalink)
New Member
Yes, the shifter moves freely and stays In position but when in gear You hear
grinding of and on trying to catch a gear.
Ron
Old 06-12-2008, 05:15 PM   #4 (permalink)
JC-jetro's Avatar
Ron
Ron,
Does it grind when in gear and clutch pedal fully pushed in all the way? if so, then release fork may need to be adjusted closer to the fingers on the pressure plate allowing you to fully disengage engine to transmission input shift.
JC,
__________________
Old 06-13-2008, 02:12 PM   #5 (permalink)
New Member
Thanks for your help jc. I am gonna work on it tonight.
Ron
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
