Grading 702C Front Blade on a TC30 ? Help with pics !
   / 702C Front Blade on a TC30 ? Help with pics ! #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
Folks, various info on the TC30 says that a 702C front blade is compatible with my machine as well as others. The only pics I can find is of the blade mounted to a TC33. It seems it would mount differently to a TC30. The used one I found has brackets, but they may be specific for a certain model. The seller does not know anything about this item or what machine it came off of. I am willing to make my own brackets, but some pics of any applications would help. Does anyone have any pics or advice in this area ?
   / 702C Front Blade on a TC30 ? Help with pics ! #2
Jerry,
I think it is the same with the mowers and the loaders. The mowers and loaders are the same for the different tractors but the mounting brackets are different. I know when I got my TC29D with the 7308 Loader they ordered three diffferent sets of mounting brackets before they had the right ones. I wished I had pictures of the blade but I don't.
murph
Here is the update on the 702C installation on my TC30. See my thread here for the complete story on the deal.
To install the blade, I needed to remove the front bracket for my 7308 loader. See pic. I plan to fabricate an alternate attachment scheme this summer so I don't have to remove this part next year.
I'm not sure which tractor this blade was set up for, but it bolted right in place with no modification. I can't believe I got this lucky. The hardest part of the whole project was finding the 14mm fine thread bolts that I needed for the rear mounting points. See pic.
The shaft for the lift cylinder was rusted. I cleaned it with chrome polish and 000 steel wool. It cleaned up pretty well, but it is pitted. End result: it leaks a little but not enough to drip.
Here is the finished project. See pic
Another
Total cost of this project was $1,000 including new hoses and bolts. (14mm fine threads were $2.50 each !)
Last pic
   / 702C Front Blade on a TC30 ? Help with pics ! #9
Nice pics and good work Jerry!
Max
   / 702C Front Blade on a TC30 ? Help with pics ! #10
Question; what is the width of the blade. Also when it is fully angled what is the width. I assume fully angled it still is wider than wheel width. Also when pushing snow how is the steering. Can you steer or is the pressure off the front end. Thanks
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
(INOPERABLE) MAROOKA (A50854)
(INOPERABLE)...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
