TC35DA Footwell Toolbox Does Not Fit TC35A
   / TC35DA Footwell Toolbox Does Not Fit TC35A #1
Redneck_Randy
Oklahoma
2005 New Holland TC35A
It does fit the contours just fine except for one thing, you can't go into high range. The shift bar hits the box never letting you select high range. Easy fix though. First pic shows narrowing the gap on the lower flat bar for the shift linkage.
Showing now where the shifter is located in high range.
Low range. You can guess where Mid range is. LOL
Encontered one other problem. The lower part of the shift bar now was hitting the back of the PTO safety switch. Easy fix. I popped it out and turn it around and. Wires are now on the opposite side by the shift bar.
Randy
Randy
Also added an extra nut and bolt to the box so it wouldn't rock around so much.
Randy
Randy
2009 Lincoln MKS Sedan (A51694)
2009 Lincoln MKS...
2024 Deere 317G (A50123)
2024 Deere 317G...
TIGER 201 WELDER (A51248)
TIGER 201 WELDER...
UNUSED AGT AIR COMPRESSOR W/ 420CC MOTOR (A51248)
UNUSED AGT AIR...
CASE TV450B SKID STEER (A51246)
CASE TV450B SKID...
2005 International TranStar 8600 Hydro Vac Truck (A53117)
2005 International...
