HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > New Holland/Ford > NH Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Trackback Thread Tools Search this Thread Display Modes
Old 07-14-2006, 05:20 PM   #1 (permalink)
deerhunterf350
Default NH Wheel Weights .
The manual States only use 2 weights per wheel , each weight weighing 107 lbs.
I see that PineRidge has put 3 weights on each wheel. New Holland only wants 2 weights per wheel, to reduce Stress on the Wheel/Axle Bearings.
Question to PineRidge,
Are the 3 weights on each wheel ALL the time?
If so, How long have you run the Weights ?
Have you noticed any problems from the Extra Weight?
I would think that an extra 100 lbs on each wheel , would be a lot less stress than a 900 lb weight bar on the 3PH along with the Weight of the Tractor.
Thanks
__________________
New Holland TC55DA R1 AGs, 18LA ,HM Toothbar, 2 remotes
deerhunterf350 is offline   Reply With Quote
Old 07-14-2006, 10:50 PM   #2 (permalink)
PineRidge
Super Member
PineRidge's Avatar
Default Re: NH Wheel Weights .
The dealer set the tractor up with 3 wheel weights on each side and the 3 point weight rack. However I really don't think these weights are much more than 80 pounds each, either that or I'm getting stronger moving them around.
The wheel weights are mounted 90% of the time, and have been on since the tractor was new in 2003. Haven't had any axle problems yet.
__________________
Mike
PineRidge is offline   Reply With Quote
Old 05-14-2008, 01:47 AM   #3 (permalink)
WCarp
New Member
I have question for PineRidge about adding wheel weights to a NH tractor. I believe you had a link to a picture or picture of something that was put on a floor jack to lift and position them so they could be bolted on the wheels. Is that correct? I would appreciate if you could provide that link or info since I can't find it now.
I would like to put a set on weights on each of the rear wheels on a TC-45D.
Thanks.
WCarp is offline   Reply With Quote
Old 05-14-2008, 06:44 AM   #4 (permalink)
PineRidge
Super Member
PineRidge's Avatar
This is a standard floor jack. The lift pad was removed (simply lifted off) and the welded solid steel rod substituted. It makes easy work of installing/removing weights and the floor jack will revert back to stock as well.
__________________
Mike
Old 05-14-2008, 08:11 AM   #5 (permalink)
lhfarm
Gold Member
lhfarm's Avatar
Quote:
Mike,
I miss your Web site with all your projects. It was a reference point for me. Any chance of bringing it back?
__________________
Barry
Lawson Hill Farm
NH TC40DA
'64 IH Cub Lo-Boy
'47 Willys Jeep w/ PTO & 3pt lift
http://www.farmjeep.com/
lhfarm is offline   Reply With Quote
Old 05-14-2008, 09:48 AM   #6 (permalink)
PineRidge
Super Member
PineRidge's Avatar
Barry I'm not sure why the material was deleted unless there was some problem with the sever itself. Guess that's a problem when you don't host your own material.
When I get a bit more time from my contractor job the material will be re-posted.
__________________
Mike
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
Page generated in 0.16078 seconds with 11 queries
