heymack said:
...Dargo made it sound like he doesn't have to pump into a 5-gallon can because he has a 275-gallon tank and those who use a 55-gallon drum set-up have to.
Nope. What I said was, and I quote, "It just seems like it takes more time and effort and trouble to haul 55 gallon barrels to get filled, crank the fuel into 5 gallon cans, and then still have to hold the 5 gallon cans up to fill the tractor."
That was in response to earlier statements from posters who mentioned cranking a hand crank in a 55 gallon container into a 5 gallon container to fill their tractor. What I stated was/is my opinion that doing so appears to be more hassle and trouble than it's worth. I see no reason so spend the money, time and effort for such a setup. I also stated that I failed to see any reason to use a 55 gallon container at all if it needed to be hauled around to be filled.
However, in my next post I stated that I was relating such a practice to my particular usage needs. A 55 gallon container wouldn't even fill my tractor up twice. As a matter of fact, a 55 gallon container wouldn't even fill up my tractors once if my mowers needed filled as well. Again, if you read my post, I was only looking at how I use fuel. For me, it would be a complete waste of time, money, effort and resources. For others, it may be helpful with their particular needs. My setup is small beans compared to most of my neighbors who generally have tanks that are over 1000 gallons. They may think my setup is a waste of time and money; which it would be for them. It's a similar situation with my modest setup compared to a 55 gallon container.
Before I put in my little 275 gallon tank, I used 5 high quality steel jerry cans. I say "high quality steel" because the darn plastic ones I had always seemed to leak from the spout when I used them. Since I keep my equipment pretty well spotless, that was a no go for me. Anyway, with one tractor in particular, it's a real pain in the rump to fill with 5 gallon cans since the filler cap is in the center of the hood. Needless to say, my setup with a regular automatic shutoff nozzle works much better for me than the 5 gallon gas cans but, in my situation, I don't think I'd be gaining much if anything if I used a 55 gallon container. Still, I never said that anyone would
have to use 5 gallon cans along with a 55 gallon container and a hand crank.
