What kind of Universal Tractor Earl?
   / What kind of Universal Tractor Earl? #1
KICK
Platinum Member
stilinlimbo, FLA
Mitsu 2000, Hew Holland 875, JD 125
what kind of hydraulic and gear earl do you think a Mitsubishi D2000 would use
taint gotta book on the thing, it has a common tranny and hydraulic system.
one thing for sure, if nobody know what Mitcheepussee specs, I'm gonna dump something in there and see what happens.
   / What kind of Universal Tractor Earl? #2
I suspect a standard UTF fluid would work. I can't say I have ever run across a Mitsubishi fluid spec before so I'm not sure if they have one of their own or use some other manufacturers spec.
Thanx DP.
about what I figured.
I'll use and maintain this tractor as long as I can but I doubt I'll ever be able to get parts for it if she breaks.
so UTF it is.
   / What kind of Universal Tractor Earl? #4
Mitsubishi still makes industrial equipment. I'm not sure if they might be able to get parts for you or not. Might be worth a try when the time comes.
