PaulT
Gold Member
I'm looking at gauges to install in the other bung of the 55 gallon drum I use for diesel. Most of these say they fit 1.5 inch NPT, which I think is standard on the drum. They say they need anywhere from 5" to 22" of clearance under the gauge, with float travel from 4" to 16". How can these be accurate in a 55 gallon drum if the depth is greater than the clearance distance. It seems if the clearance distance is less than the total drum height, then you will be innacurate on when it reaches E, and if the float travel stops before the top, then you will be innacurate on when it reaches F. Am I missing something, here/w3tcompact/icons/hmm.gif? Any thoughts? (BTW, I am looking on pages 85-87 in the 2001 Surplus Center catalog if you have one.)
