HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Oil, Fuel & Lubricants
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-25-2002, 03:55 PM   #1 (permalink)
Default 30-weight oil?
I went to my local Kubota/Case dealer here in Central Texas to get some oil for my first change. Sold me Case 30-weight oil "formulated for heavy-duty diesel engines". Since I asked for the "good stuff" I guess this is the best they had. I notice most everybody here uses a multi-viscosity oil. Anybody have any thoughts on using this oil?
fishman is offline   Reply With Quote
Old 06-25-2002, 05:25 PM   #2 (permalink)
Member
Default Re: 30-weight oil?
Go with whatever weight oil your manual recommends, but with the climate in Central Texas, 30 weight should be fine. We've used 30 weight in a Ford 4100 for almost 20 years up here in Northeast Texas with no problems ....got to love these Texas summers (NOT!).
DarrenP is offline   Reply With Quote
Old 06-25-2002, 09:51 PM   #3 (permalink)
Gold Member
My dealer told me the same thing, and that's what's in my BX2200.. 30W Case diesel tractor oil. He said that's all they recommend.
upgw is offline   Reply With Quote
Old 06-28-2002, 01:15 PM   #4 (permalink)
Slamfire's Avatar
If it never gets real cold 30 weight would be fine, when the temp drops much below 20 degrees then a thinner oil would be better.
Slamfire is offline   Reply With Quote
Old 06-30-2002, 11:39 PM   #5 (permalink)
I also live in Central Texas, although south of you a bit (Fredericksburg). When I purchased my John Deere, the dealer recommended 30W oil. I wondered about that so I called and talked to a technician at John Deere and was told that this was indeed the weight recommended for my tractor in the area in which I live. This is confirmed also by the graph of temperature ranges and recommended oil weights in the operator's manual.
GlennT is offline   Reply With Quote
Old 07-01-2002, 11:56 AM   #6 (permalink)
Thanks to all! The 30-weight is going in the tractor![img]/w3tcompact/icons/grin.gif[/img]
Old 07-06-2002, 10:36 AM   #7 (permalink)
Good choice. The most common viscosities for conventional diesel-rated oil are 15W40 and straight 30. Rotella is available in both, as well as a straight 40 and a new synthetic 5W40, also for diesels. But beware. Some convenience and department stores, and even some feed and seed type places, carry 30-weight nondetergent oil that has only an API SA rating--that is, you may as well say, no rating at all. The only use for this oil would be in antique cars (before 1955) that were not designed to use today's oils, and even then today's oils would be better after an engine rebuild or a careful flush. The nondetergent 30-weight does not meet any diesel specs or any API spec newer than SA, which has been obsolete for over 40 years. Usually it's pretty cheap, which is why you must be careful when you buy straight 30 oil. Make sure the oil meets current API specs for diesels (CG, CH, etc.).
ekrampitzjr is offline   Reply With Quote
Old 07-06-2002, 12:05 PM   #8 (permalink)
Epic Contributor
Bird's Avatar
<font color=blue>The only use for this oil would be in antique cars</font color=blue>
Well, almost the only use maybe.[img]/w3tcompact/icons/wink.gif[/img] There are some electric motors for which it is recommended, and it's also used in the impact mechanism of a lot of impact wrenches and some other air tools.[img]/w3tcompact/icons/laugh.gif[/img] So I keep some on hand, but of course, I don't use it in any gasoline or diesel engines.
Bird is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
