Go Back   TractorByNet.com > General Forums > Oil, Fuel & Lubricants
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-10-2009, 09:46 PM   #41 (permalink)
Super Star Member
Location: First organized permanent settlement in the northwest territory
Default Re: A decent fuel can?
Quote:
Originally Posted by scotty088 View Post
I found a fill-rite 15 gpm 12 volt electric pump complete with hose,filter and nozzle for $75.00 on craigslist.It takes longer to hook up to the 12 volt battery than it takes to fill the tank.My local Petrolium dealer gave me a new clean 55 gl. barrell for buying my off road diesel from him.This is the best set-up shy of having your own gas station.You guys are going to use your Tractors and implements for years.Why not make it easy on yourselves.....I don't spill a drop......
Scotty
A verry verry good point.
__________________
Tractors 2003 Kubota BX1500/2004 Kubota Bx23/New- Kubota BX1500
Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
60'' MMM/Clamp on Forks/48'' MMM
South of Canton Ohio L .B
LBrown59 is offline   Reply With Quote
Old 10-11-2009, 05:04 PM   #42 (permalink)
fishpick's Avatar
I lost my mind trying to refuel the other day... flew into the house like a raving lunatic screaming about politics and fuel cans... Trail of blue air a mile long as I drove to the store. I took a brass plumbing fitting, heated it with a torch and then pressed it THROUGH the top back flat surface of the handle on my "no vent - no pour - Liberal fuel jug" - made a hole about .455" in the plastic - no shavings like you would get with a drill. Then took and dropped a new valve stem into the big hole on the jug and rolled it around spilling what little fuel was left - feeling vindictive the whole time - until a small wire would be all I needed to pull the tip out my new hole. Grabbed the stem with a pair of pump pliers and then pulled the stem out and set her. Then used a core remover from the auto store and pulled the center of the valve stem. Filled the pair of "Freedom Fuel Jugs" - unscrewed the valve stem cap - and wouldn't you know it... they pour like, well, you would expect. Total cost to modify the 2 jugs - $5 for valve stems and core removal tool. Fact I'm screwing the man - priceless.
__________________
For the latest in what's going on around the farm and homestead visit Chicken Thistle Farm or follow our Tweets
fishpick is offline   Reply With Quote
Old 10-11-2009, 05:46 PM   #43 (permalink)
Glad to see the idea worked. Funny thing is it came to me as i was sitting here, and hasn't been tried by me or anyone that I know till you. Sounds like it worked good.
Bedlam is offline   Reply With Quote
Old 10-15-2009, 03:05 PM   #44 (permalink)
wedge40's Avatar
Quote:
Could we have a photo please. I'm a visual kind of guy. I've alway though about drilling and putting valve like they have on the bottom of air tanks to bleed that water out into the gas can.
Wedge
__________________
1967 Ford 4000, Box blade, straight blade, FEL, Rake, Bushhog, Backhoe, Jinma chipper, KKII tiller, Grapple.
wedge40 is offline   Reply With Quote
Old 10-29-2009, 05:12 PM   #45 (permalink)
fishpick's Avatar
wedge40 - attached are two shots I took - but nothign fancy about the "how to" process.
I can tell you now I have filled them - stored them for a bit - and then poured into tractors... you need a funnel to get the contents in - but it comes out of the jug nice and does not splash all over like it used too.
I'm happy!
__________________
Old 10-29-2009, 07:06 PM   #46 (permalink)
I never thought I'd see the day when the old style fuel cans became desirable to have for their simplicity and working.
Somebody is going to figure out how to "correct" the fuel spout end of these cans.
2manyrocks is offline   Reply With Quote
Old 10-30-2009, 01:22 PM   #47 (permalink)
fishpick's Avatar
Quote:
Originally Posted by 2manyrocks View Post
I never thought I'd see the day when...
I have heard a lot of people saying that about a lot of things lately...
__________________
Old 10-30-2009, 02:54 PM   #48 (permalink)
You can find the old style cans at Briggs and Stratton dealers if they can be purchased in your state.
Solo
__________________
Photos
Solo is offline   Reply With Quote
Old 10-30-2009, 05:44 PM   #49 (permalink)
fishpick's Avatar
@Solo - Nope - this is NY... home of the CARB compliant gas can... and several other wonderful things...
__________________
Old 10-31-2009, 08:37 PM   #50 (permalink)
i bought one for my deisel. It is spill less. I put it into the tractor fuel neck, then pull the switch and then push the lever down no problem? I m not sure how you can spill it dont pull the trigger. Put the spout into the filler neck fuel flow cut off, then push down and pull the lock out switch back and fuel starts to flow. The problem i have it that it takes twice as long to put fuel in the tank.
clemsonfor is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.07056 seconds with 9 queries
