Re: 7.3 powerstroke oil change I found and watched the Powerstroke 7.3 youtube vids about changing the oil in the inj tank. That is what got this question thread started. I wanted to check out what other experts had to say. No one around town has ever heard of changing the oil. I've checked it after a oil change and found the oil to be good,not gunky or dirty. I also lost the plug screw. New one cost $7 at the delaer.
After all the discussion, I think the prudent thing to do is not to worry with vacuuming out the oil and changing it every time, but to check the condition after every oil change. If it is in good shape, I believe the oil is getting pumped thru the tank as it should and overflowing back to the sump. No further special action is required. Without the check, there is a chance the overflow may be clogged and prohibiting a good exchange,causing excessive inj wear.
Rgds,
tim
__________________ "It's only Me 'n I'm home from the Sea..." |
