jd950 fuel filter help
   / jd950 fuel filter help #1
sal64
ny orange county
jd 2320 jd 990 jd950
hello all i have a jd 950 the fuel filter has never bean changed it only has 193hrs, the tractor runs fine, should i change the filter? is it a 100_4898.jpg
100_4899.jpgpain to blead the air out? i looked at the manual and no were to blead the air out any tips would be much appreciated tuvm.
   / jd950 fuel filter help #2
hello all i have a jd 950 the fuel filter has never bean changed it only has 193hrs, the tractor runs fine, should i change the filter? is it a View attachment 150186
View attachment 150187pain to blead the air out? i looked at the manual and no were to blead the air out any tips would be much appreciated tuvm.
Yes it's time you can bleed the filter with the 2 Phillips head screws at the top.
