crazyal
Super Member
How old is your truck? If it's an older truck then I say go for it. If it's brand new and you don't mind giving up the warranty then have fun. I personally would do it if I had an older car or truck with a diesel. I'm just not sure how easy it would be to blend the oils and not have them separate. Plus I am cheap and I would want to run 100% veggie to get the best savings. I also don't think trying to process it is worth the effort.
A pick-up would be an ideal choice. Lots of room to add a second tank. I've seen the oil heated using radiator fluid but I think I would use electrical heat tape and a heating pad. I've also seen timers to switch between diesel and veggie to avoid having it gel in the injectors. So I say if you have a source, have a truck you don't mind experimenting with, and don't mind getting your hands a little dirty then go for it.
I for one would like to hear how it works out for you.
