Jay4200
- Joined
- Nov 23, 2005
- Messages
- 2,053
- Location
- Hudson/Weare, NH
- Tractor
- L4200GST w/ LA680 & BX2200D w/ LA211
OK, I did search but I have not found the answer.
Kubota M9540 - manual says for the front axle case and the front differential that you can use either UDT Hydraulic fluid OR SAE 80-90 gear oil.
There is a big difference in these two types of oil. Dealer says they put in UDT Hydraulic fluid whenever they do fluid changes.
I am not questioning the dealer, I just wonder how the thinner hydraulic fluid can be OK for the axle case and differential.
It's not really all that different. UDT is equivalent to about a 20w (SUDT is ~10w), and 80-90 gear oil is roughly 30wt, so they are pretty close. Gears don't care.
I'm running 85w-140 in mine. It's like molasses in January. Not to say it's the best thing to put in there, but it helps keep my bezel seal leak under control
JayC
