Page 1 of 6 1234 ... LastLast
Results 1 to 10 of 54
  1. #1
    Platinum Member bironacad's Avatar
    Join Date
    Jan 2011
    Posts
    603
    Southern Ontario, Can
    New Holland 3045/2010
    Default When do you use the block heater on the tractor
    Okay I own three diesel vehicles, car, truck and now a tractor. I never plug in the car and truck unless it is below -19 C -2.2 F. My tractor really sputters on start up at a couple of degrees below freezing and was wondering what the collective wisdom is on when to plug it in. I let them all warm up before use, lol.
    Thanks
    “If at first you don't succeed, you are running about average.”
    M. H. Alderson
  2. #2
    Join Date
    Apr 2011
    Posts
    2,406
    St. Cloud MN
    Deere 4100
    Default
    In the winter I'll use the block heater (& hydraulic heater) whenever I'm going to use my CUT which is stored in my unheated garage. I plug it in an hour before using. I don't have heaters in my (Diesel) cars but if I did I would use them. Located in central Minnesota.
  3. #3
    Join Date
    Jan 2011
    Posts
    603
    Default Re: When do you use the block heater on the tractor
    Quote Originally Posted by rsewill View Post
    I have plugged it in but not always you do it as a matter of course?
    M. H. Alderson
  4. #4
    Join Date
    Feb 2011
    Posts
    825
    Furakawa 351
    I plug in equipment if at all posible, I do it like stated just an hour, unless it is below 0F then maybe more it is a lot cheaper to warm it with electricity than fuel and the engine wear is greatly reduced.
    I am not a believer in long idle periods, 5 minutes at most then just use it gently, till the coolant gauge starts moving or it is above 100F.
  5. #5
    Join Date
    Jan 2011
    Posts
    603
    anyone use remote switching
    http://www.tscstores.com/TIMER-3-OUT...TE-P17002.aspx
    My problem is that my barn/garage is maybe 700' away, yes I am looking for the easier softer way. I would use x-10 but it has been known to do strange things on power outages and such.
    Attached Thumbnails Attached Thumbnails When do you use the block heater on the tractor-320654.jpg
    M. H. Alderson
  6. #6
    Platinum Member amigauser's Avatar
    Join Date
    Oct 2005
    Posts
    948
    Unionville, Connecticut USA
    Kubota Grand L 3240HST
    Quote Originally Posted by bironacad View Post
    I use something similar but only has one outlet that is a heavy duty version designed to light up christmas displays. Works very well. I am only around 50 feet from that tractor garage and I also put a two way splitter with an outside light so when I turn on the block heater the outside light also lights (letting me know the on command was received and it is powered on). I also run mine for one to two hours and only in the winter months when it is below 30 degrees.
    I actually start the tractorafter the hour or two with the block heater still on to aid in warming. I let it warm up for about 10 minutes, unplug the heater and then slowly work the tractor to heat the hydraulic oil and drivetrain.
    Kubota Grand L3240HST, LA724 FEL with QA, 72" QA bucket, Turf Tires, QA snow plow, QA Loader Buddy, Bradco Pallet Forks, 72" Ratchet Rake. Leinbach 72" pine straw rake, GroundWorks brush forks and Kubota L series ballast box.
    Kubota Orange RTV 500
    Stihl stuff
  7. #7
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    5,217
    north idaho
    dk45se hst cab
    My heaters are on a timer that runs 2 hours prior to the times i generally use my tractor. And its only plugged in when temps can reach below 30 at night.
    Right now im not needing tractor for snow work, so it hasnt been plugged in for past 3-4 weeks.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  8. #8
    Join Date
    Apr 2011
    Posts
    2,406
    St. Cloud MN
    Deere 4100
    Default
    Yes. But like Johnp33, I'm not a believer in long idle times, maybe a minute no matter the temperature with my tractor. With my Diesel cars if it is shirtsleeve weather, no warmup. At freezing, about 30 seconds which is the length of time it takes me to buckle my seat belt, adjust the mirror, turn on the radio, etc. At 0F, I'll idle a minute and drive off slowly. At -40 I'll idle the cars for several minutes My two cars (VW's) have computers that let the engine run at higher RPM's by 'slipping' (for lack of a better word) the transmission when it is cold. I'm a so-called 'hypermiler' so I take it easy anyway.
  9. #9
    Gold Member
    Join Date
    Jan 2012
    Posts
    338
    Northern Washington
    John Deere 3005
    Shop is heated, but always let her idle for 5 minutes before any throttle. But John deere says any temps below 10f should have a block heater.
    2011 John deere 3005, already waxed 5 times.
    I drives me boat ! My wife drives me dingy !
  10. #10
    Join Date
    Jan 2011
    Posts
    603
    Quote Originally Posted by Jamming View Post
    I plug it in a little before it gets to 10F -12 C
    Quote Originally Posted by amigauser View Post
    The light idea is good it lets you know if you forgot to turn it off too.
    M. H. Alderson
Similar Threads
  1. JD 790 Battery,Maintainer & Block Heater Install
    By Trails2004 in forum John Deere Owning/Operating
    Last Post: 01-01-2011, 08:48 PM
  2. BX 25 Block Heater revisited....
    By Dpm708 in forum Kubota Owning/Operating
    Last Post: 12-02-2010, 05:43 PM
  3. Block heater question on Kubota tractor
    By allthingsoutdoors in forum Owning/Operating
    Last Post: 01-24-2010, 06:17 PM
  4. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 10:56 AM
  5. Stupid Block Heater Questions...
    By bcarter in forum Kubota Owning/Operating
    Last Post: 12-12-2000, 08:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
