Results 11 to 20 of 21
02-23-2012, 12:58 PM #11Platinum Member
- Join Date
- Jun 2009
- Posts
- 625
- Location
- Nowhere
- Tractor
- 1878 Ford 65N
Re: 55 Gallon barrel storage issue and more
I have a blue plastic 55 gal drum here for my diesel fuel. I have a cheap cast-iron rotary pump in it. It is located inside my shed under cover as I wouldn't trust the bungs and pump to be water tight. My pump has a threaded collar and it fits into my drum nicely. There are two different threads on my barrel (fine for a vent bung and a coarse for the pump fitting).
I have about 10 ft of hose to reach the tractor in the shed.
It is sure nice to go get a full drum twice a year and not have to man handle 5 gal cans. It takes about 20 cranks to fill my tank on my tractor.
02-23-2012, 01:05 PM #12Super Member
- Join Date
- Jul 2009
- Posts
- 6,445
- Location
- Georgia - Mt. Vernon by The Store just 5 miles east and right by the big oak tree then to the creek.
I have a 55 gallon plastic drum and when I bought it I also bought an HF hand pump...it fell apart before I could finish pumping the firs gallon of fuel...I took it back...It did not fit good either on the barrel..I went to Tractor Supply and bought a hand pump for about $60.00 and it works fine...no water in fuel and the pump is great.
Bob
NH - TC-29 , FEL, Bush hog, Bush hog brand finishing mower, Post hole digger, 6' Back blade, sub-soiler, Pallet forks, 20KW PTO Generator , 21 hp Murray Mower
JD -3020 with FEL and a 16 HP. K-Grow Lawn Tractor (bought from K Mart 1994) and runs great !
02-23-2012, 02:13 PM #13Veteran Member
- Join Date
- Nov 2008
- Posts
- 2,306
- Location
- South Central Iowa
- Tractor
- TYM 330 HST with FEL
I also have plastic barrel for diesel fuel. It has two bungs. One has the same thread as the steel barrels. The other has very coarse thread. I bought 12V Northern Tools pump and filter that is permanently mounted on the barrel. The pump is powered from the tractor when refuelling. The barrel is on a dolly now so I can pull it to the tractor.
Ladia
TYM 330 HST with FEL, box blade, rotary mower, post digger, three point sprayer, homemade backhoe, Jinma chipper, Leinbach rake and Lincoln 255XT MIG.
Tasker harrow disc, PTO driven 5 cuft concrete mixer. My wife Julie has Grasshopper 725K.
We live in a barn (aircraft hanger) converted into a house. Our PV system: https://enlighten.enphaseenergy.com/...ems/h2eX136588
http://pvoutput.org/intraday.jsp?id=20209&sid=18073
02-23-2012, 06:27 PM #14Super Star Member
- Join Date
- Jul 2011
- Posts
- 10,528
- Location
- Yanceyville, North Carolina
- Tractor
- Kubota L4400
I have enjoyed reading the posts in regards to fuel storage in plastic barrels. Another additional way that I use those barrels for is garden tool storage. I cut the top off, add a concrete block in the bottom for stability, and put all my garden tools in it such as Shovels, post hole diggers, hoes, racks, brooms, mattocks; etc. I have it in one of my sheds and these tools stay in one easy assessable place and they don't take up much storage space.
The PUPIL who does not surpass his Master, fails his Master.
02-23-2012, 10:20 PM #15Super Star Member
- Join Date
- Oct 2004
- Posts
- 16,843
- Location
- First organized permanent settlement in the northwest territory
- Tractor
- 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
1*You need to use the fine thread.
The coarse is to thread a vent into the center of the cap.
2*Still should have worked with the proper fitting on the drum.
3*No
4*Stay with the plastic.
5*The problem is there is no pipe fitting to screw into the drum after removing the cap .
Worse yet nobody makes such a fitting .
I solved that problem by building my own.
Fitting
This end stays Outside of the drumb.
This end goes inside the drumb
This is a picture of the fitting installed on the drum
Without this fitting it's basically impossible to successfully get the suction tube through the top into the drum and acheve the desired results.
02-25-2012, 07:39 PM #16Super Star Member
- Join Date
- Oct 2004
- Posts
- 16,843
- Location
- Tractor
1*They are the same on my plastic and steel drums.1*The bungs on plastic barrels are a different thread then metal ones.
2*The pump you bough is built for metal barrels.
3*I ran into this same issue and what I did was make an adapter with parts from the plumbing section of the hardware store.
4*As for getting water in the fuel why in the world did you leave $400 of fuel sitting outside in the first place?
5*I would keep it in the barn and out of the weather.
6* L Brown is the owner of a plastic barrel storage system and I am surprised that he hasn't hit this yet.
7*He has a rather complicated valving arrangement that does more than just dispense.
8*Good to know that there is no pump for a plastic barrel.
9* I am not sure how you found parts for this at a plumbing store .
10*Diamond, you have any pix of your solution?
11*I can easily get 55 gallons with my tractor in and out of the truck, but 110 is just on the edge of not lift able.
12*So much for my fancy tractor.
13*I still think I can do this better, just have to figure out how.
14* We have a pole barn that is just a roof, no sides.
15*The barrel pump seal was never tight.
16*I will start looking for a steel barrel,
17*I just like the ability to see my status with the white barrel I am using.
18*Thanks again guys for the ideas and such
My blue plastic 55 gal drum is located inside my shed under cover .
19*I wouldn't trust the bungs and pump to be water tight.
20*There are two different threads on my barrel
21*(fine for a vent bung and a coarse for the pump fitting).
22*I have about 10 ft of hose to reach the tractor in the shed.
I also have a plastic barrel for diesel fuel. It has two bungs.
23*One has the same thread as the steel barrels.
24*The other has very coarse thread.
25*I bought a 12 V Northern Tools pump and filter that is permanently mounted on the barrel.
26*The pump is powered from the tractor when refueling.
27*The barrel is on a
2*The pump should work on plastic and steel drums.
3*There is no plumbing fitting that will allow you to go through the top of a drum so you can get a tight leak proof connection .
I had this one special made and it is the only way I know of to successfully get through the top of a drum
and achieve a leak proof connection .
4*I put mine in this little 8 x 10 building .
5*A barn would work too.
6*I never ran into it.
7*It's not really all that much more complicated but it greatly expands the functionality of it. .
8*No it's not good to hear .
What's good to know is the pumps will work on both Steel and plastic drums.
9*I searched high and low for a fitting like this and it turns out no plumbing manufacturer makes such a fitting.
10*You solution is to make a fitting like his one as you can't buy one any where.last picture shows the fitting installed in the drum.
11*You don't need to do any lifting with my set up so I just leave my tractor parked .
12*Plumb your barrel like mine and you won't need your tractor because there is no lifting or moving heave drums.
13*I'm trying to show you how.
14*Put in there as far as you can get it = better than outside.
15*They never are so that's why you need this.
16*No need to do that just use the plastic one that you already have.
17*You mean so you can see how much fuel is in the drum like I can with this one.?
18*You are welcome .
19*Main problem on that is the sloppy way the pumps are plumbed through the top of the drums.
20*Actually there are 2 caps but 3 different threads on all of the plastic drums I have seen .
A-One hole is a 2 inch regular pipe thread .
B-The other hole is a 2 inch with a real course thread.
C-The cap with the real course thread. has a 3/4'' standard pipe thread in the center of it for a vent pipe.
21*You have it backwards it should be *(The fine is for the pump fitting & a course bung is to put a vent in)
22*My hose is 12 feet.
23*That's why any pump can be plumbed to it .
24*That's so you can add a vent pipe.
25* I mounded the red pump to a shelf when I realized it was better to drive the tractor rather than get involved in all the hassles of transporting the drum to the tractor.
26*Mine's powered by this and it keeps the charger stored handy yet out of the way ,
27* Much easier and simpler to take the tractor to the drum. Simplifies things greatly..
_________________
02-25-2012, 08:22 PM #17Platinum Member
- Join Date
- Jan 2006
- Posts
- 871
- Location
- West Central Idaho
- Tractor
- Grand L5740HSTC, Kubota LA854 FEL with QA Bucket
Have you thought of gravity flow from an IBC?
On and offloaded with forks, the valves are robust, easy to fab a platform, and it would be easy to plumb a Goldenrod water separator filter between the valve and the fill hose.
02-25-2012, 11:27 PM #18Super Star Member
- Join Date
- Oct 2004
- Posts
- 16,843
- Location
- Tractor
1*You must not have had a water seperating filter on
The pump like this
or you would not have pumped water into your tractor.
It's the round white screw on filter connected to the red pump.
He would not have goten water in his tractor if he had a water seperating filter on his pump.
3*Better yet he needs to install a water seperating filter on his pump.
02-26-2012, 10:11 AM #19Super Star Member
- Join Date
- Oct 2004
- Posts
- 16,843
- Location
- Tractor
02-26-2012, 01:29 PM #20Platinum Member
- Join Date
- Jan 2006
- Posts
- 871
- Location
- Tractor
