i have mahindra model 2810 i don't know where the oil drain plug is.
Apr 22, 2012 / oil drain plug #1 S susieq New member Joined Apr 22, 2012 Messages 2 Location hunt texas Tractor mahindra 2810 i have mahindra model 2810 i don't know where the oil drain plug is.
Apr 22, 2012 / oil drain plug #2 WilliamBos Super Member Joined May 1, 2004 Messages 5,316 Location Innisfil, Ontario, Canada Tractor MF 1635 12x12 Powershuttle Do you have an owners manual? It should show it? Last edited: Apr 22, 2012
Apr 22, 2012 / oil drain plug #3 clemsonfor Super Member Joined Sep 11, 2009 Messages 9,853 Location Greenwood Co., SC Tractor Yanmar YM2000 susieq said: i have mahindra model 2810 i don't know where the oil drain plug is. Click to expand... Not being "smart" or anything, but look underneath it, on the bottom of the engine. It will have to be there on the bottom of the oil pan.
Apr 22, 2012 / oil drain plug Thread Starter #4 OP S susieq New member Joined Apr 22, 2012 Messages 2 Location hunt texas Tractor mahindra 2810 susieq said: i have mahindra model 2810 i don't know where the oil drain plug is. Click to expand... when i looked on the bottom it has two plugs side by side so which one is it
Apr 22, 2012 / oil drain plug #5 clemsonfor Super Member Joined Sep 11, 2009 Messages 9,853 Location Greenwood Co., SC Tractor Yanmar YM2000 Are both on the Oil pan? If so it should not matter, but if there is any distance between them one is probly on the transmission for your Hydro fluid and one is on the OIL pan for the engine oil.
Apr 22, 2012 / oil drain plug #6 WilliamBos Super Member Joined May 1, 2004 Messages 5,316 Location Innisfil, Ontario, Canada Tractor MF 1635 12x12 Powershuttle If the driveshaft goes through the pan, then you will need to pull both. Below is the oil pan on our MF 1635. See the two plugs closest to the front axle, those are the pan plugs on this tractor. Can you take a pic for us? Then somone on here should be able to help you out. Last edited: Apr 22, 2012
Apr 23, 2012 / oil drain plug #7 moored4 Veteran Member Joined Jan 31, 2011 Messages 2,368 Location Great NorthWest /Southwest Washington Tractor Kubota l245dt, l3540, 8N Due to the shape of your pan they both need to be removed so all of the oil can drain! Your pan is shaped like upside down U ?
