Page 5 of 11 FirstFirst ... 2345678 ... LastLast
Results 41 to 50 of 107
  1. #41
    Super Star Member Mace Canute's Avatar
    Join Date
    Nov 2006
    Posts
    10,024
    Saskatoon, Saskatchewan
    Default Re: I hate new fuel cans so here is what I did.
    Years ago I decided to drill out the small stock hole in the vent on a plastic gas container just to see what difference it would make to the amount of time it took to empty it. This was the old style can everybody remembers and likes so much. I drilled as large as I could without getting into the threaded wall of the vent and was pleasantly surprised when it made a significant improvement. It's been so long ago I can't remember how much exactly, but it was definitely worth it. The vent cap still sealed just as good as ever too.
    We can still buy the old style vented containers here in Canada!
  2. #42
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    7,102
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds operating weight
    Eagle and Justrite "lifetime" metal cans are readily available, most cheaply on amazon.com...... free shipping no sales tax.
    While the purchase price is twice higher than plastic cans, these are "lifetime" quality and you do not have to fool around to achieve no spill, no drip, rapid flow.
    Available red, yellow, green, blue.
    Be sure to specify widest diameter spout.....various diameters are available.
    I have a slight preference for the Justrite design but both Justrite and Eagle are excellent.
    Attached Thumbnails Attached Thumbnails I hate new fuel cans so here is what I did.-img_0353-jpg   I hate new fuel cans so here is what I did.-img_0349-jpg   I hate new fuel cans so here is what I did.-img_0352-jpg   I hate new fuel cans so here is what I did.-img_0348-jpg   I hate new fuel cans so here is what I did.-img_0350-jpg
  3. #43
    Join Date
    Jun 2012
    Posts
    162
    Mid, Michigan
    Kubota L3540 w/ LA514 FEL, 66" QA Bucket, 48" QA Forks, 7' RB, 18" Ripper, Ferris IS2000z ZTR
    I never spilled so much gas as when I was trying to use these new EPA cans. I believe this group has gotten to a point where they are passing regulations without any knowledge on what they are doing.
    I got myself a few of these to fix the worthless spouts and add a vent. Check out ezpour. I also got some of the hi-flo ones.
    UNIVERSAL GAS SPOUT EZ-POUR
  4. #44
    Gold Member duroc's Avatar
    Join Date
    Feb 2012
    Posts
    340
    Michigan
    NH T1510 HST
    Quote Originally Posted by PhilY View Post
    UNIVERSAL GAS SPOUT ォ EZ-POUR
    Each to their own, but I don't have much luck with those flexible spouts. It seems they always spring back and throw fuel all over the place. I do, however, like the "1/2 replacement push in vent" that comes in the kit. I wish those were available to purchase without the other items.
    "If con is the opposite of pro, is Congress the opposite of progress?"
  5. #45
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,115
    Peoria IL
    New holland TC(33)
    so there is a kit out there. EZ-POUR
    i picked up 5. They come with new nossels (with screw caps) and the kit also includes the old fashion snap in vent for your "water can only"
    I had 2 diffrent cans that ive used this on. One i lost a cap for. the other the nosel plastic got old and broke in half. I added the real vents to 2 other "water" cans.
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  6. #46
    Gold Member cletus99's Avatar
    Join Date
    May 2012
    Posts
    287
    Doerun, GA
    2011 Kubota L3800HST
    Has anyone used the Scepter Duramax Flo-n-Go from TSC. It's expensive, but if it works it could be worth it. Looks like it would be slow to fill with the small hose.
    Scepter Duramax Flo-n-Go, 14 gal. cap. - Tractor Supply Online Store
  7. #47
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    Bump for another member.
    Chris
  8. #48
    New Member
    Join Date
    Nov 2012
    Posts
    10
    Mebane, NC
    Kubota
    Quote Originally Posted by cletus99 View Post
    I bought one of those and hooked it up to a 12V pump for diesel fuel. Haven't even tried the gravity-feed nozzle it came with. Raising up a 14 gallon container to allow siphoning seems like a big negative, but if you use a crank or powered pump it is not a problem to keep the tank at ground level.
  9. #49
    Gold Member PRF's Avatar
    Join Date
    Dec 2012
    Posts
    267
    Connecticut
    2012 Kubota L5740, 1970 IH 2444, John Deere x485
    Quote Originally Posted by Diamondpilot View Post
    I keep 30 gallons of fuel on hand and I hate the newer cans. Here is my fix. I used standard valve stems with the schrader valve removed. I drilled a 1/2" hole on empty dry fuel cans. Then with a piece of balling wire fish it though the hole drilled from the main hole. Pull it through with a valve stem took and seat it.
    For the newer style can with the spring loaded fill neck I disassembled it and used some 5/8" plastic chair leg caps.
    Chris
    Great idea with the tire valve stem... Learn something every day here !! Kudos
  10. #50
    Silver Member mikesee's Avatar
    Join Date
    Apr 2012
    Posts
    226
    wilmington, de
    BX2660, RTV 900, RTV 1140 CXP, B21, KX-018-3, KX 121-4
    Default
    Container Identification System. Not sure where I poached this idea but it works great for me and the people in my shop. I use 1 zip tie for gas, 2 for two-cycle abd 3 for diesel.
    Attached Thumbnails Attached Thumbnails I hate new fuel cans so here is what I did.-image-971803390-jpg
Similar Threads
  1. Non carb fuel cans for race fuel
    By Schwermetall in forum Oil, Fuel & Lubricants
    Last Post: 05-05-2011, 09:06 PM
  2. Oil & Fuel Ventless fuel cans...
    By The Dougster in forum Owning/Operating
    Last Post: 05-25-2009, 05:34 PM
  3. A question on diesel fuel and cans
    By smallfarmer in forum Oil, Fuel & Lubricants
    Last Post: 06-08-2008, 06:24 AM
  4. I got my new fuel cans
    By kubotajoe in forum Oil, Fuel & Lubricants
    Last Post: 10-02-2006, 07:21 PM
  5. Fuel cans
    By Anonymous Poster in forum Oil, Fuel & Lubricants
    Last Post: 06-29-2003, 06:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
