Page 1 of 11 1234 ... LastLast
Results 1 to 10 of 107
  1. #1
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default I hate new fuel cans so here is what I did.
    I keep 30 gallons of fuel on hand and I hate the newer cans. Here is my fix. I used standard valve stems with the schrader valve removed. I drilled a 1/2" hole on empty dry fuel cans. Then with a piece of balling wire fish it though the hole drilled from the main hole. Pull it through with a valve stem took and seat it.
    For the newer style can with the spring loaded fill neck I disassembled it and used some 5/8" plastic chair leg caps.
    Chris
    Attached Thumbnails Attached Thumbnails I hate new fuel cans so here is what I did.-forumrunner_20120629_133911-png   I hate new fuel cans so here is what I did.-forumrunner_20120629_133922-png
  2. #2
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,359
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: I hate new fuel cans so here is what I did.
    Quote Originally Posted by Diamondpilot View Post
    Chris
    I understand the schrader valve well enough.. but the last part about the 5/8 chair leg caps.. I don't understand at all. Pictures? ( I hear tell they are worth about 1000 words )
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  3. #3
    Silver Member ricklman's Avatar
    Join Date
    Apr 2012
    Posts
    107
    Mena, AR
    Kioti CK30 HST
    Yep, I think we've all installed the valve stems based on a thread or two on the site... I'm with James, what's up with the caps? Are those the little yellow thingies in the pics? If so, that makes me think of the threads about fishing stuff out of your diesel tank
    Rick
    Kioti CK30 HST / KB2475 Backhoe / KL130 FEL / Box Blade
    Pi are Round, Cornbread are Square.
  4. #4
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Look at the second pic. I used the cap to close off the fill neck after I gutted it of all the spring loaded crap.
    Chris
  5. #5
    Join Date
    Jun 2009
    Posts
    28,359
    Branson, Mo.
    Chris
    Oh I see... I am getting along OK with my lever action Blitz.. (they dont make them any more, now it is a push on the edge of the filler neck to actuate thing). I did remove the safety though.
    James K0UA
    James K0UA
  6. #6
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Default
    Here is a pic to help out.
    Chris
    Attached Thumbnails Attached Thumbnails I hate new fuel cans so here is what I did.-forumrunner_20120629_145642-png
  7. #7
    Join Date
    Jun 2009
    Posts
    28,359
    Branson, Mo.
    Chris
    Yeah that is one of the new ones the stores are full of.. I did not want one of those.. I found an old stock lever action can, in a low volume store, and it works pretty well. Especially if you pull out the safety mechanism. Of course yours probably works pretty good now.
    James K0UA
    James K0UA
  8. #8
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Default
    Quote Originally Posted by k0ua
    James K0UA
    Add a vent like I did with the valve stem and it will work great.
    Chris
  9. #9
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,880
    Ontario, NY
    Kubota BX24
    kudos !!! hopefully the feds will take notice and change the darn mandates on fuel cans.....
  10. #10
    Platinum Member DEWFPO's Avatar
    Join Date
    Jun 2007
    Posts
    919
    "High in the Rockies"
    2009 Bobcat Toolcat 5600 D
    Unless those black plastic chair leg caps are made of HDPE (which I doubt), they likely will not hold up to gasoline well.
    DEWFPO
    2009 Toolcat 5600 "D-Series", Hi-Flow, 29's, 72" SB-200, 84" Snowblade, 62" Lo-Pro Bucket, Titan HD 48" Pallet Forks
    SOLD - 2006 MF GC2300, 2350 FEL, 2315 MMM, 2360 SB, KingKutter CarryAll
Similar Threads
  1. Non carb fuel cans for race fuel
    By Schwermetall in forum Oil, Fuel & Lubricants
    Last Post: 05-05-2011, 09:06 PM
  2. Oil & Fuel Ventless fuel cans...
    By The Dougster in forum Owning/Operating
    Last Post: 05-25-2009, 05:34 PM
  3. A question on diesel fuel and cans
    By smallfarmer in forum Oil, Fuel & Lubricants
    Last Post: 06-08-2008, 06:24 AM
  4. I got my new fuel cans
    By kubotajoe in forum Oil, Fuel & Lubricants
    Last Post: 10-02-2006, 07:21 PM
  5. Fuel cans
    By Anonymous Poster in forum Oil, Fuel & Lubricants
    Last Post: 06-29-2003, 06:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
