Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 48
  1. #31
    Join Date
    Feb 2009
    Posts
    50
    Upstate NY
    New Holland TC34DA
    Default Re: I need a diesel transfer tank (opinions wanted)
    What about static electricity? Are any of you worried about that or have something setup to neutralize it? I would be worried about that especially with the plastic drums. But would like your opinion because I need a tank too and have been struggling with worrying about static, and also moving the tank full. I like the idea of the square tank TSC has and strapping it to a pallet for transport.
  2. #32
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    Quote Originally Posted by stonypass View Post
    Thanks for the additional pics.
    You mentioned using 1/2" ID hoses, the one's on the input side of the pump look larger than the one on the output side of the filter.
    Perhaps its just because they are closer to the camera?
    You are right They are 5/8 inch .
    I had to buy hose 2 different times because I didn't get enough the first time.
    I didn't notice I got the 5/8 by mistake the second time until I started putting it all together so i went ahead and used the 5/8 instead of having to run back to town for the 1/2.
    Either one will work but if i ever have to replace the hose i would switch the 5/8 hose and go with the 1/2 .
    If i were to build another rig I would use all 1/2 like i intended to do in the first place.
    *Another thing i'd like to point out is the white fitting on the end of the curled hose hose hanging on the wall .
    It is a filter to keep dirt and other crud out of the pump and fuel.
    It is a foot valve purchased at Lowes that I motified into a filtering screen.
    I first tried putting a piece of screen over the hose and clamping it on with a hose clamp however this didn't work when i tried pumping fuel from a 5 gallon can because the hose clamp was to big to fit into tne can opening.
    Thus the white fitting that drops right into a fuel can.
    Quote Originally Posted by TeamNH View Post
    Static electricity is only a priblem with gasoline .
    There is little or no issue with diesel.
    Build a system like mine and forget about moving containers of fuel.
    I wouldn't trade my rig for 3 of the TSC tanks.
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  3. #33
    Join Date
    Apr 2012
    Posts
    67
    Southwest MO
    Kubota L4200-GST 4WD
    Earlier you mentioned the vent and needing to keep the original barrel's plug.
    Did you modify the plug, or did it come with a smaller plug that when removed left a hole that was threaded to fit the vent tube?
    Kubota L4200-GST 4WD, LA680 FEL, 6' Mower, 6' Box Blade, 7' Angle Blade, 12kw 3pt PTO Generator
  4. #34
    Bronze Member hbarski's Avatar
    Join Date
    Apr 2005
    Posts
    70
    Tenn/Arkansas
    3930 Ford/Newholland Mitsubishi MT2001D CASE 580 CK
    This is a simple diesel tank I fabricated from an old refer trailer. I picked up the tank and saddle for $100. The pump and filter from Northern tools for another $100 and I have it sitting on a wooden platform with 8 wheels that I made from scrap around the shop. I fabricated the angle iron frame out of scrap around the shop.
    I pick it up with the front end loader and place it into the truck bed and take it to go fill it at the local off road diesel station a few miles away. Bring it back and off load it back on to the roller platform and move it around my shop. It took me a weekend playing around cutting and welding but it all was pretty much straight forward and works great.
    Attached Thumbnails Attached Thumbnails I need a diesel  transfer tank (opinions wanted)-refer-tank-jpg
    Light travels faster than sound, that is why some people appear brighter before they speak......
  5. #35
    Join Date
    Apr 2012
    Posts
    67
    Southwest MO
    I like it, looks like a simple mechanical gauge to show fuel level.
    Might be able to get a tank from a truck salvage, how many gallons does the it hold?
  6. #36
    Join Date
    Apr 2005
    Posts
    70
    Tenn/Arkansas
    50 gallons. Try to get it with the saddle bands and mount. Around here they usually sell for about $1 a gallon, I paid a little more because I was in a hurry and he had the mount too.
  7. #37
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    This is a good view of the vent screwed into the cap.
    The cap has a 3/4 inch pipe thread in the center with a knock out in it .
    I just took a 1/2 inch drill and drilled through the center of the knock out .
    1/2 is plenty as you don't want to go so large that you screw up the 3/4" threads in the cap.
  8. #38
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    7,039
    Northern Vermont
    Kubota, Case, Deere
    I just use a metal 55 gallon drum with a pump screwed into it. It sits on a wooden frame with cheap HF wheels under it. I put quick disconnects on the fuel line and power cord so they can be easily removed. Since I burn heating oil I don't have to worry about bringing it anywhere to be filled, just have it filled when they fill my HHO tanks. It';s simple but works fine and being mobile it's easy to move out of the way.
    I need a diesel  transfer tank (opinions wanted)-s7300896-jpg
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  9. #39
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Well I finally got around to taking some pics of the fuel set up. My set up is similar to LBrowns but is made to able to load in my truck to get fuel(no delivery in my area). The fuel pump sets on the top rails and is easily removed by springing the sides in a little and lifting the unistrut bracket off the cage. I just set a battery on the top rail while fueling but will likely make a tray for it when I figure exactly what I want.
    I need a diesel  transfer tank (opinions wanted)-dscn0001a-jpgI need a diesel  transfer tank (opinions wanted)-dscn0002a-jpgI need a diesel  transfer tank (opinions wanted)-dscn0003a-jpgI need a diesel  transfer tank (opinions wanted)-dscn0004a-jpgI need a diesel  transfer tank (opinions wanted)-dscn0007a-jpgI need a diesel  transfer tank (opinions wanted)-dscn0009a-jpg
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  10. #40
    Join Date
    Apr 2012
    Posts
    67
    Southwest MO
    Thanks for the pics, I assume PVC and Diesel work ok together?
Similar Threads
  1. Diesel Transfer Tank/Pump Questions
    By geewhz01 in forum Oil, Fuel & Lubricants
    Last Post: 08-24-2011, 08:53 AM
  2. Same transfer tank for Diesel and Gasoline?
    By Boiler74 in forum Oil, Fuel & Lubricants
    Last Post: 12-26-2010, 01:22 PM
  3. Oil & Fuel Fuel Transfer from Diesel Truck's Tank?
    By ouderstad in forum Owning/Operating
    Last Post: 06-11-2009, 04:55 PM
  4. Diesel fuel transfer tank bottom plug - plastic?
    By BarryinMN in forum Oil, Fuel & Lubricants
    Last Post: 03-12-2004, 12:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
