Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
  1. #31
    Join Date
    Jun 2011
    Posts
    220
    Connecticut
    Default Re: FUELING FRUSTRATION
    LBrown59, thanks for the very detailed response!
    I do have a generator that runs when power is lost, so 120VAC is always there for me. I'm just trying to keep things simple (though I'd be the first to admit that we're already past that at this end).
  2. #32
    Super Member
    Join Date
    Nov 2003
    Posts
    8,384
    Central Michigan
    4210 MFWD Ehydro--'89 JD 318
    Keep things simple...do you really use enough fuel per year to justify the expense of a fancy fueling setup? As for me, I have an old milkhouse with a concrete pad inside that is the ideal height to set a 55 gallon drum on and use a hose to refill my tractor....but...why bother? For my purposes all I need to do is fill three 5 gallon diesel cans four or five times a year. SIMPLE SIMPLE SIMPLE.
  3. #33
    Elite Member
    Join Date
    May 2005
    Posts
    2,794
    Balls Creek, NC
    New Holland t4.75
    Just a thought...
    My dad utilized a transfer tank that stayed in his pickup bed...
    Used it to refuel his dozer, loader, backhoe, ect...
    Had a small electric pump that attached to the battery...
    Worked great...
    No lifting of 5 gal cans plus the added convenience of refueling to remote locations...
    I've still got it...
  4. #34
    Silver Member nwltruck's Avatar
    Join Date
    Nov 2010
    Posts
    158
    north west Iowa
    '07 John Deere 3320
    Default
    Simply went to local hardware store and bought a small liquid pump that mounts in a drill. I have one long hose on the suction side and a short hose on the discharge side simply uses a cordless drill. Love it because i drive truck and if the tractor needs fuel i pull alongside the truck and siphon it out of the tank into the tractor. Takes about 10 minutes. Would work with about anything
  5. #35
    Super Member
    Join Date
    Oct 2003
    Posts
    7,345
    Northeast, Ohio
    TC-40D SS New Holland
    Here's our setup. You can get these fuel oil tanks cheap if you watch the local paper or Craigslist. There's always someone putting in a new high eff furnace that switches from fuel oil to nat gas. We got 2 for free so far.
    The pump came from Northern Tool. The local oil company comes to our place to fill it when needed.
    Attached Images Attached Images
  6. #36
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    Quote Originally Posted by Turbys_1700 View Post
    Just a thought...
    *My dad utilized a transfer tank that stayed in his pickup bed...
    Worked great...
    *The main peroblem is theft hauling it around all the time and loss of bed space.
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  7. #37
    Join Date
    Jun 2011
    Posts
    220
    Connecticut
    Quote Originally Posted by JDgreen227 View Post
    I'm currently using 5 gallon cans. But I've tired of having to climb up on the operator platform to fill my tank and also the spillage onto the hood that sometime results. I started this thread to find a better way.
    (I didn't realize this thread had continued since my last post. For some reason, I no longer receive an email when a response has come in.)
  8. #38
    Join Date
    Jun 2011
    Posts
    220
    Connecticut
    Just a thought...
    Worked great...
    I completely agree. In fact, I haven't yet moved on this because we're currently looking at more acreage (~100 or so). If that happens, I'll need the tank in the pickup to fill other machines and the problem will solve itself.
  9. #39
    Join Date
    Jun 2011
    Posts
    220
    Connecticut
    Quote Originally Posted by PineRidge View Post
    It all depends on how much fuel you need to keep on hand. Prior to looking at some additional land (see prior posting), this would have been too much fuel and I'd worry about the fuel going bad before I used it. Your suggestion is now a viable option. Another great idea -- thanks!
  10. #40
    Join Date
    Jun 2011
    Posts
    220
    Connecticut
    Quote Originally Posted by LBrown59 View Post
    I've thought about the loss of bed space, but not about theft -- haven't heard that happening around here. But it's certainly a possibility. Thanks!
Similar Threads
  1. Mass Frustration
    By Realsecman in forum New Member Introductions
    Last Post: 10-04-2010, 09:03 PM
  2. disk frustration!
    By HCJtractor in forum Attachments
    Last Post: 09-08-2010, 09:23 AM
  3. frustration nh 8870
    By jeff mabbitt in forum New Member Introductions
    Last Post: 07-24-2010, 04:23 PM
  4. Appliance Frustration
    By N80 in forum Related Topics
    Last Post: 12-06-2009, 06:42 PM
  5. Snow Snow Frustration
    By MFChief in forum Massey Ferguson Owning/Operating
    Last Post: 01-25-2005, 06:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
