Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Gold Member Teikas Dad's Avatar
    Join Date
    Aug 2012
    Posts
    367
    Live Free or Die
    Kubota B3200
    Default Poly storage tanks for fuel storage
    Saw these on CL:
    Poly Storage Tanks: water food fuel WVO biodiesel
    Poly storage tanks for fuel storage-5n95g55je3n23i13n2c9qd6bb23c009ea1ec1-jpgPoly storage tanks for fuel storage-5n25g75f43g33m23j8c9q7362bf60acd11ad6-jpg
    Has anyone ever used one of these for diesel storage? I like the metal cage for protection.
  2. #2
    Elite Member Ken45101's Avatar
    Join Date
    Feb 2009
    Posts
    3,440
    southern Ohio
    Kubota M5040, M9540, B21 TLB, B2710, RTV900, JD 325 Skid steer, KX-121-3 mini excavator
    Default Re: Poly storage tanks for fuel storage
    Yes, there have been a number of threads about them. I've been using one for about four years now. I put an electric pump on it.
    I would suggest keeping it out of the sun to reduce degradation of the plastic.
  3. #3
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,899
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    The black plastic wont degrade as fast as the white from ultraviolet rays but the white will allow you to see the liquid level. Keep the white one inside and it will be good for many years.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  4. #4
    Join Date
    Feb 2009
    Posts
    3,440
    southern Ohio
    Quote Originally Posted by Gary Fowler View Post
    I've never seen a black one, I didn't know they exist.
    However, black would absorb more heat if sitting out in the sun. I don't know if that would cause more problems.
  5. #5
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    8,119
    Central Square, NY
    LS XR3037HC
    I just replied to another thread about the same thing. I use a 15 gallon poly tank for refueling my tractor. As mentioned you can see the fuel level in the white one. I use a cheap 12V electric fuel pump with a small trailer brake battery for power.
  6. #6
    Gold Member cschulz's Avatar
    Join Date
    Jun 2011
    Posts
    281
    Ortonville,MI
    Kubota BX2660
    My fuel provider suggested not to use plastic and the fuel and sunlight will break down the plastic.
    Chris
    2011 Kubota BX2660 Loader/ 60"Mower
    My Tractor Tools QA and Grapple System
    BT601 Back Hoe
  7. #7
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Quote Originally Posted by cschulz View Post
    Chris
    Your kubota tank is plastic
    Murph
  8. #8
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    Here is my plastic fueling station .
    I's 5.5 years old and I haven't had a plastic break down .
    If your fuel supplier was correct all the plastic cans from the big box stores auto parts places convenience stores etc would be failing right and left because they are same as these drums.
    Quote Originally Posted by murphy1244 View Post
    Correct.
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  9. #9
    Join Date
    Feb 2009
    Posts
    3,440
    southern Ohio
    And metal tanks rust
  10. #10
    Join Date
    Jul 2003
    Posts
    630
    under the elephant\'s tail [ ontario can.]
    john deere 3130, universal
    Biggest concern would be what was in them before. I have one for livestock water that had silicon in it before. I could wash most of it out and I know it won't hurt the water but it would be terrible in fuel.
Similar Threads
  1. Large poly water storage tank question-
    By Skyco in forum Rural Living
    Last Post: 09-29-2016, 08:46 PM
  2. Fuel storage
    By olivedrabflorida in forum Oil, Fuel & Lubricants
    Last Post: 06-13-2012, 04:47 PM
  3. Cheap 100g storage tanks
    By zuiko in forum Oil, Fuel & Lubricants
    Last Post: 09-14-2003, 10:35 PM
  4. Diesel Storage Tanks
    Last Post: 07-10-2003, 12:34 PM
  5. fuel storage tanks
    By eteagle in forum Rural Living
    Last Post: 11-11-2002, 11:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
