Traveller/TSC oil
   / Traveller/TSC oil #1
JustinE
I'm wondering if anybody has experience with TSC's brand of oil, Traveller. I know it's by Warren Products but haven't found any real reviews. What's your take?
   / Traveller/TSC oil #2
Make sure it's stamped API approved if it's an engine oil.
As for a hydraulic / tractor fluid... I would stick to a major brand. Most off brands do not meet the new spec's for the smaller / newer tractors.
   / Traveller/TSC oil #3
I put the Ford Tractor Gear Oil (SAE90/GL-1) in the spicer transmission and rockwell transfer-case of my 1966' deuce-and-a-half, 1500 miles so far and no problems.
   / Traveller/TSC oil
I was only thinking motor oil and gear oil for equipment.
   / Traveller/TSC oil #5
I've used it for my massy 1225 10 years ago with no problems, just match the labels with the needs, good luck
   / Traveller/TSC oil #6
Warren makes good stuff. I use lots of their grease and gear oils. Just make sure the API rating is right for your unit.
Chris
   / Traveller/TSC oil
Thank you! I was kinda worried about the off brand labeling.
   / Traveller/TSC oil #9
I use Traveler 10W-30 in our 2008 Trailblazer, 60k miles, no problems yet!
   / Traveller/TSC oil #10
the specs are right ont he side of the traveler oil.
the premium utf meets most.. ( probably not thf.. etc.. )
I've used warren oils for years.. no lube related failures.
