Page 11 of 12 FirstFirst ... 89101112 LastLast
Results 101 to 110 of 117
  1. #101
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    7,009
    Northern Vermont
    Kubota, Case, Deere
    Default Re: Oil Filter Comparison
    A little light reading about oil filter failures.
    http://www.aftermarketsuppliers.org/...ish/88-3R2.pdf
    The last engine I built for my race car, a SBC 350, I replaced the oil pump. The pump instructions said that the over pressure hole on the side of the pump must not be restricted. The fact is that oil pumps are no different than a hydraulic pump in your tractor, two gears meshing. The pressures they can reach if the over pressure valve fails are in the 1000s of psi range. That's well beyond the range an oil filter can handle. Oil pumps are designed to dump the excess pressure out of the over pressure hole and back onto the oil pan. The flow of the pump is designed to include that oil flow as well as the oil going to the filter. If that hole gets plugged or the valve itself fails then it's up to the oil filter and the engine's bypass valve to deal with the excess flow and pressure. If you do a search for "collapsed oil filter" you find all sort of "don't buy Fram" sites but if you look a little further you'll find almost every brand filter collapsed.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  2. #102
    Super Star Member daugen's Avatar
    Join Date
    Feb 2012
    Posts
    10,261
    Washington NC (Inner Banks)
    Kubota L5740HSTC, MF 2615, MF 1230, IH Super A
    I guess that's why buying a heavy case filter like a K&N or a Mobil 1 makes sense in that application. When you've got your blood sweat and tears in a motor, a couple extra bucks for a filter makes sense to me.
  3. #103
    Super Member
    Join Date
    Nov 2003
    Posts
    8,384
    Central Michigan
    4210 MFWD Ehydro--'89 JD 318
    Quote Originally Posted by daugen View Post
    Agree 100% about the extra $$ for a quality filter is well spent. I change the oil and filter on my GMC once a year...what's an extra $5 for the K&N? And the heavy case makes it easier to remove the filter when you have to stick a screwdriver thru it for removal...
  4. #104
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Quote Originally Posted by mikehaugen View Post
    I can get one, just didn't think that would be of interest to you guys. It can be telling of an engine I suppose, but didn't know if you could take much from it from a filter quality standpoint. What in particular are you looking for so I can try to get a picture that will be useful? Close up of the fibers?
    I just wanted to see how close the pleats in the filter media were.
  5. #105
    Gold Member
    Join Date
    Apr 2010
    Posts
    344
    There are huge differences between oils that just meet the minimum specifications and those that exceed the minimum specifications.
    The same thing goes for filters
    Statements like these are what results in folks searching the internet or talking to other people looking to uncover some "secret".
    If an engine manufacturer comes up with a specification for an engine oil or filter, (or anything else for that matter), they don't come up with that set of specifications based upon the end-user operating that engine with kid gloves only under the optimum set of circumstances. Any "minimum spec" any engine manufacturer comes up with for an appropriate oil or filter, means that that specification is adequate.
    Far too much of this "minimum spec" nonsense is used to sell stuff that isn't necessary and will provide no benefits. It's just as ridiculous as making a similar statement about a "minimum spec" for sizing the wiring in your home for a receptacle being inadequate.
    So-called "minimum specs" simply are not teetering on the brink of failure like some folks, (and companies), want to you believe.
  6. #106
    Elite Member
    Join Date
    Mar 2009
    Posts
    3,607
    Lee, IL
    John Deere 1070
    Here you go Roger, is this what you were looking for?
    Oil Filter Comparison-untitled-6-jpg
    Oil Filter Comparison-untitled-5-jpg
  7. #107
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,796
    A cheap oil filter may save a little money now, but it can cost you dearly in the end. Been there, done that.
  8. #108
    Super Member
    Join Date
    Nov 2003
    Posts
    8,384
    Central Michigan
    Quote Originally Posted by MasseyWV View Post
    I recall the ads Fram had at one time: "You can pay a little more now, or a lot more later" and it seems ironic now, given the negative reputation Fram seems to have for filters.
    Just FYI here: I owned nothing but Ford products from 1978-1998, and used nothing but Fram oil filters in every engine my vehicles had. Back then Fram was considered a very good product and I had no misgivings whatsoever about the quality.
  9. #109
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,583
    Greenwood Co., SC
    Yanmar YM2000
    As of right now i dont go looking for frams to use but if it is on a deal i get i use it on one of the older vehicles. I have to admit most of my hesitance is from this internet "lore" of them, BUT i do admit that looking into the filters i sometimes see plastic in them when i use to see metal in the same application, which has driven me away more than the so called falure stories that you hear on the net.. Massey being the first to actually say that it happened to him on one of his vehicles with a fram.
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  10. #110
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Thanks for posting.
Similar Threads
  1. Replies: 8
    Last Post: 06-22-2012, 06:50 PM
  2. Replies: 2
    Last Post: 09-12-2011, 10:02 AM
  3. oil comparison?????????
    By whitearrow in forum Oil, Fuel & Lubricants
    Last Post: 06-16-2006, 11:44 PM
  4. 284 LE oil & filter exchange & tilling comparison
    By corey in forum Chinese Tractors
    Last Post: 08-09-2005, 02:13 PM
  5. Kubota OEM and WIX (Dana) Oil filter comparison
    By DelfinoTX in forum Oil, Fuel & Lubricants
    Last Post: 04-10-2005, 12:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
