Page 6 of 12 FirstFirst ... 3456789 ... LastLast
Results 51 to 60 of 117
  1. #51
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Quote Originally Posted by buddd View Post
    Hi , I just bought a new 2013 massey ferguson GC 1710 . It replaced the GC 2610,2410,2310 . I found I need a NAPA GOLD 1360 engine oil filter , but what Hydraullic oil filter do I need , also what air filter do I need as the owners manuals tells nothing !! Thanks Bud
    A lot of the times the hydraulic filters are only availabke at the dealer. If you had the number you may be able to cross it over. If you ask in the MF forum someone may k,now.
  2. #52
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,921
    Northern Vermont
    Kubota, Case, Deere
    Default Re: Oil Filter Comparison
    Quote Originally Posted by Soundguy View Post
    speaking of filter oem brands.. etc.
    I was picking up an oil filter for my yukon.. pf61 is the ac delco OE filter. it was 40 cents cheaper than the purolater and the fram filter setting next to it on the shelf.
    Looking at the filter.. feeling it.. weight..e tc. I'd BET the fram extra guard ( which was the most expensive of the 3 ) was a better filter. but heck.. i figure you can't go wrong with the ac delco filter in the book for your truck.. etc.
    On ford. look at the fl1a motorcraft filter. it crosses to ph8a fram, st8a supertech.. napa 1515 auto application, 1452 other appl..e tc.
    the fl1a can be had for 2.99$ in some places.... that's cheaper than any of it's cross reference.
    I have seen people on the internet (so I can't confirm) saying that the same company that makes the filters for AC Delco also make the STP filters. The STP filters are usually the cheapest filters on the shelves. They could be made differently, or maybe not?
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  3. #53
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,659
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Quote Originally Posted by crazyal View Post
    i know the stp and ac delco filter are close in price at walmart for my yukon.. with the fram being a tad more.. just frome weight.. the fram weighs more too
  4. #54
    Join Date
    Mar 2002
    Posts
    52,659
    Central florida
  5. #55
    Elite Member
    Join Date
    Mar 2009
    Posts
    3,588
    Lee, IL
    John Deere 1070
    you can say that again!
  6. #56
    Join Date
    Mar 2002
    Posts
    52,659
    Central florida
    Quote Originally Posted by mikehaugen View Post
    i'm not sure why it double posted.. but assume it was part of the board hiccup that happend. I didn't purposefully double post.
  7. #57
    Elite Member
    Join Date
    Mar 2009
    Posts
    3,588
    Lee, IL
    John Deere 1070
    I know it wasn't on purpose, I see it all the time, just for some reason this time I had to make a comment.
  8. #58
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,547
    Greenwood Co., SC
    Yanmar YM2000
    Quote Originally Posted by 94BULLITT View Post
    The duplicolor kind leaves a fairly rough coating. I guess it will hold up to heat
    Heck the coating on a fram if oil gets on it and with the heat and time it flakes off.
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  9. #59
    Join Date
    Sep 2009
    Posts
    8,547
    Greenwood Co., SC
    Yanmar YM2000
    Yea we still are dealing with that double post issue? I have done it a few times myself i see recently?? What happended to the outcome of that Dbl post thread we had like a year ago going and Muhhamad was "looking " into it?
  10. #60
    Join Date
    Mar 2002
    Posts
    52,659
    Central florida
    Quote Originally Posted by clemsonfor View Post
    they have been holding up for me on a tractor.. 1 year anyway. though no oil gets on them.
    a lil gas sometimes from over choke though.
    they are cheap enough to chage out more often if they do get damaged though..
Similar Threads
  1. Replies: 8
    Last Post: 06-22-2012, 07:50 PM
  2. Replies: 2
    Last Post: 09-12-2011, 11:02 AM
  3. oil comparison?????????
    By whitearrow in forum Oil, Fuel & Lubricants
    Last Post: 06-17-2006, 12:44 AM
  4. 284 LE oil & filter exchange & tilling comparison
    By corey in forum Chinese Tractors
    Last Post: 08-09-2005, 03:13 PM
  5. Kubota OEM and WIX (Dana) Oil filter comparison
    By DelfinoTX in forum Oil, Fuel & Lubricants
    Last Post: 04-10-2005, 01:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
