Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
  1. #31
    Silver Member PandDLong's Avatar
    Join Date
    Apr 2012
    Posts
    100
    Southern Alberta
    Kubota L3540
    Default
    Here's a pic of the old and new side-by-side -- kinda easy now to figure out why it wasn't gripping properly
    Why won't my grease gun hold onto the zerk?-image-703435797-jpg
  2. #32
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Why won't my grease gun hold onto the zerk?
    it needs dentures!
  3. #33
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,760
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Quote Originally Posted by PandDLong View Post
    Kinda looks like a tip that has been unthreaded about half way.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  4. #34
    Join Date
    Apr 2012
    Posts
    100
    Southern Alberta
    Kubota L3540
    Default
    In that picture they are both threaded tight and I measured the aperture and it's the same - so that old tip is just out of whack.
  5. #35
    Elite Member Redneck in training's Avatar
    Join Date
    Nov 2008
    Posts
    4,236
    South Central Iowa
    TYM 330 HST with FEL
    Take the nozzle apart and reassemble it. I think one of the jaws is out of position.
  6. #36
    Platinum Member High Compression's Avatar
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Kubota L5740-3/ Kubota ZD21 pro60
    Bingo! You might have ruined the end by having it too tight and pulling it off the zerk. There are two or four little jaws in there that hold on to each side of the zerk, and they are probably worn or bent. I would just put a new end on. Should be good to go!
    "It is better to be thought a fool, than to open your mouth and prove it."
  7. #37
    Join Date
    Jun 2008
    Posts
    10,760
    Bismarck Arkansas
    Obviously you have a new 4 jaw tip, so just toss the other one, loosen the threads on the new one so it can be hand adjusted so next time you have a hard time getting it off the zerk, you can just loosen it by hand to remove it.
Similar Threads
  1. Removing stuck grease nipple from grease gun
    By Don1025 in forum Parts/Repairs
    Last Post: 05-12-2011, 08:20 PM
  2. Can't get the grease gun off the grease fitting..am I retarded?
    By Sniggle in forum Oil, Fuel & Lubricants
    Last Post: 12-14-2009, 03:34 AM
  3. Grease/Grease Gun Accessories information?
    By USMC2531 in forum Oil, Fuel & Lubricants
    Last Post: 10-08-2009, 03:35 PM
  4. Grease gun wouldn't go from zerk.
    By Redneck in training in forum Oil, Fuel & Lubricants
    Last Post: 11-26-2008, 08:54 AM
  5. Replies: 21
    Last Post: 09-13-2008, 11:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
