Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 50
  1. #11
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    Default Re: Off road Diesel versus #2 home heating oil
    Quote Originally Posted by PHIL850 View Post
    I am getting conflicting information on #2 fuel oil (heating oil) versus off road Diesel fuel. The Driver that delivered our last load of heating Oil told me you can no longer Use #2 heating oil in a Diesel engine because they have removed all the Cetane from it.
    We have a couple of 275 gal tanks at our place that feed the oil burner and I would love to be able to tap off of those to fill my John Deere 850 on occasion. Diesel burns fine in the oil burner, and if the price were comparable why not fill the tanks with Off road Diesel? What say you?
    Hmmm . if cetane was removed ,, it wouldnt combust right? therefore your furnace wouldnt be "burning it" ?
  2. #12
    Join Date
    May 2012
    Posts
    2,199
    Me
    Mahindra Max28XL HST
    Default
    (edit: picture upload unreadable -- post deleted until I can figure out a solution)
    Attached Thumbnails Attached Thumbnails Off road Diesel versus #2 home heating oil-forumrunner_20130408_101230-png
    http://www.ohr.edu/838
    https://www.youtube.com/watch?v=U9BfhxL_JTI
    https://www.youtube.com/watch?v=J8UEVoSJmfs
    “If you continue in My word, then you are truly disciples of Mine;and you will know the truth, and the truth will make you free.” Ancient of Days
    My soul finds rest in God alone; my salvation comes from him.
    http://www.youtube.com/watch?v=37aM75LaEDk&list=PLGLwt3_lSbxxRtjMLHJDpqEK 9vcq9IfsJ
    t
  3. #13
    Join Date
    Mar 2011
    Posts
    610
    Florida Ma.
    Ford 1720 SSS 4x4 Turbo Charged
    Google Cetane for additional information.
    90cummins
  4. #14
    Silver Member PHIL850's Avatar
    Join Date
    Apr 2006
    Posts
    108
    MASS and Northeast kingdom of VT
    JD 850
    Cetane keeps Diesel from preignition when injected. It is like the OCtane for gasoline.
  5. #15
    Join Date
    Mar 2011
    Posts
    610
    Florida Ma.
    That is incorrect.
    This is the definition from about .com
    Similar to the octane number rating that is applied to gasoline to rate its ignition stability, cetane number is the rating assigned to diesel fuel to rate its combustion quality. While gasoline's octane number signifies its ability to resist auto-ignition (also referred to as pre-ignition, knocking, pinging, or detonation), diesel's cetane number is a measure of the fuel's delay of ignition time (the amount of time between the injection of fuel into the combustion chamber and the actual start of combustion of the fuel charge).
    Because diesels rely on compression ignition (no spark), the fuel must be able to auto-ignite--and generally, the quicker the better. A higher cetane number means a shorter ignition delay time and more complete combustion of the fuel charge in the combustion chamber. This, of course, translates into a smoother running, better performing engine with more power and fewer harmful emissions.
    90cummins
  6. #16
    Veteran Member D7E's Avatar
    Join Date
    May 2006
    Posts
    2,251
    manitoba
    Many
    When our heating oil is delivered it comes from the same batch as the farm diesel . Truck pumps 1500 gal into the farm diesel tank then 500gal into the house as he leaves !
  7. #17
    Join Date
    Dec 2006
    Posts
    1,437
    Coastal Rhode Island
    Jinma 354, purchased 2007
    I'm in Rhode Island. When I call up my local fuel oil supplier and ask him to fill my fuel oil tank, I get an invoice that says diesel on it.
  8. #18
    Join Date
    May 2012
    Posts
    2,199
    Me
    Default
    Quote Originally Posted by D7E
    Then, you are very likely heating your house with ultra low sulpher diesel. Not heating oil.
    t
  9. #19
    Join Date
    May 2006
    Posts
    2,251
    manitoba
    Many
    Quote Originally Posted by madmax12 View Post
    I dont know but i only had oil heating for 18 years and it's always been that way... just dyed farm diesel .
  10. #20
    Join Date
    Sep 2010
    Posts
    165
    Michigan
    Landini 85F Deere 5425 Ford 1920
    Quote Originally Posted by D7E View Post
    Same thing here.
    #2 is heating oil. We use three different distributors, and all of them do the same thing. Shop oil tank gets filled, bulk tanks get filled.
    Same stuff getting sold to the folks in the city that burn oil.
    ULSD heating oil? Whatever.
Similar Threads
  1. Off Road---Home Heating oil
    By etcallhome in forum Oil, Fuel & Lubricants
    Last Post: 03-16-2011, 05:49 PM
  2. Oil & Fuel Home heating fuel = Off road diesel?
    By pyro6988 in forum Kubota Owning/Operating
    Last Post: 01-08-2010, 06:04 PM
  3. Is #2 home heating oil identical to #2 diesel fuel?
    By Snatchface in forum Oil, Fuel & Lubricants
    Last Post: 06-22-2007, 07:12 PM
  4. Oil & Fuel Home heating oil = Diesel?
    By Dan_w in forum Kubota Owning/Operating
    Last Post: 04-28-2006, 06:40 PM
  5. Oil & Fuel #2 heating oil, Road diesel, or K1 kerosene
    By brad_oatley in forum New Holland Owning/Operating
    Last Post: 01-12-2005, 11:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
