Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Veteran Member Jay4200's Avatar
    Join Date
    Nov 2005
    Posts
    2,011
    Hudson/Weare, NH
    L4200GST w/ LA680 & BX2200D w/ LA211
    Default Running tractor on Kerosene?
    If I fill up my tractor (kubota L4200) with Kerosene, what will happen? Would it be good or bad for it? Kerosene is about the same price as road diesel these days - if it's better for it, maybe I should use it? I don't really know the difference between Kerosene and diesel/fuel oil, but I know that I can use Kerosene in my oil furnace.
  2. #2
    Join Date
    Mar 2011
    Posts
    610
    Florida Ma.
    Ford 1720 SSS 4x4 Turbo Charged
    Default Re: Running tractor on Kerosene?
    A diesel engine injection system that operates at thousands of psi is different than an oil furnace which operates at low pressure.
    Kerosene is a more highly refined product than diesel so it has even less lubricating properties than ULSD.
    It can definitely damage your fuel system.
    Don’t use it!
    90cummins
  3. #3
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    the old school way to lower freezing point is to mix kerosene with diesel in really cold climates. Nowadays its not a general practice anymore, but its been done. I wouldnt run straight kero as it would burn too hot. Guess what it might do to the engine? With kero nowadays, there seems to be documentation saying there is not enough lubricity for the newer engines.
  4. #4
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,927
    Northern Vermont
    Kubota, Case, Deere
    Around here kerosine comes dyed for off road and clear for on-road. Usually the stuff at the pumps is off road since I think it's rare to see anyone blending kerosine with diesel for winter use. I ran a 50/50 mix of it for one summer because I had too much left over from winter. Didn't have any problems but the engines sure start quick. I would use an additive that will add a lubricant to the fuel.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  5. #5
    Join Date
    Jun 2008
    Posts
    50
    Winchester, CT
    MF 1533
    My uncle had a late 1970's White tractor (made by Fiat, I think). He ran it on straight kero in the winter for many years, never had any fuel system problems that I remember. As has been said, the old school fuel systems were much less fussy about what they pumped.
    MF 1533, 1525 loader, loaded R4's
  6. #6
    Elite Member Ductape's Avatar
    Join Date
    Feb 2006
    Posts
    4,856
    Central New Hampshire
    Kubota B3030HSDC
    I have bought Kerosene in bulk off of Craigslist in the past. I mixed it with diesel (around 60 / 40 ) and added a little Power Service (silver) and ran it in my kubota with no problems.
  7. #7
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,629
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel
    That is a good question that I would like to read some printed facts about.
    We ran kerosene (JP-5) in all kinds of non military diesels when I was in Spain in the 1970's without any known issues that I heard about or experienced in that era of diesels. Now the military gas cut the seals out of one guy's newer Volvo gas injector pump so he had to buy gas off base.
    I think some try to run diesels on soybean juice today so they must still run on non diesel fuels.
  8. #8
    Platinum Member spruce Deere's Avatar
    Join Date
    Feb 2009
    Posts
    758
    Northmost Idaho
    John Deere 790 w/ 300 loader
    Straight kerosine no, not in today's wimp diesel engines.
    I would cut my diesel with kerosine like ductape states, if I found myself that low on diesel and absolutely had to stretch it.
    Last few years I have been using PS 'white bottle' year round. The tractor noticeably starts better, smokes less and runs smoother.
    To me, the cost of running the additive is scratch compared to jelled fuel in winter, premature injector or pump fail...... Pay a little now, or alot later.
    Eventually things DO wear out, the longer I can avoid that the better.
    Boy these fuel threads.....
    790 JD W/ 300 loader
    Lots of implements for loader and 3pt
    Can't do it burn'n diesel, is not worth do'n
  9. #9
    Veteran Member brain55's Avatar
    Join Date
    Jan 2008
    Posts
    1,817
    Brentwood, CA
    This is the only thing I've ever run straight kerosene in, lol.
    Running tractor on Kerosene?-2215_1030877576969_7541_n-jpg
  10. #10
    New Member
    Join Date
    May 2013
    Posts
    8
    Columbia, MO
    Ford 9N modified, T head Gravelys
    Quote Originally Posted by Gale Hawkins View Post
    JP-5 is a kerosene based jet fuel but it is not straight kerosene. K-1 Kerosene has no lubricity and will tear up a diesel pump, but military multifuel engines can burn it. JP-5 is usually okay in diesels with Bosch style pumps but not distributor pumps as in VW (who made the Volvo diesel).
    K-1 will even tear up a jet engine fuel pump. Jet A, JP-5 has a lubricity spec but it's low. JP-8 is a fuel designed for both turbine and diesel engines. Adding oil will usually make it acceptable for lubricity but it has to be an oil with good high pressure qualities. Power Service has this oil in it.
    At the airport we ran Jet A in a international fuel truck with the 466 engine and added Power Service to it. Never a problem.
Similar Threads
  1. Kerosene in tractor
    By Slab in forum Oil, Fuel & Lubricants
    Last Post: 11-15-2012, 10:20 AM
  2. Tractor running hot
    By Mark Dolan in forum Oil, Fuel & Lubricants
    Last Post: 06-25-2012, 06:58 PM
  3. New here and hoping to get help getting tractor running.
    By Bob Warner in forum All Other Brands
    Last Post: 02-03-2008, 12:02 PM
  4. Kerosene in the tractor
    By Scrounger in forum Oil, Fuel & Lubricants
    Last Post: 12-10-2007, 10:55 PM
  5. Tractor Not Running for Blizzard Help!!!
    By Mikek101 in forum John Deere Owning/Operating
    Last Post: 01-25-2005, 08:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
