Results 1 to 7 of 7
  1. #1
    New Member Bayouownbeer's Avatar
    Join Date
    Sep 2012
    Posts
    23
    Chauvin LA
    2012 John Deere 4105
    Default John Deere Break in Plus 10w-30
    Can this oil be used in other applications such as lawn mowers in such or a Chevy 350 v8. Reason I ask is because we have 10 gallons left from a New John Deere Genetator that is not being used. I have read that only difference is it is a non-detergent oil Vs detergent.
    John Deere 4105HST 300cx loader
    imatch,72" bushhog, 72" finish mower, 72" box blade, 60" disc, 48" forks and middle buster.
  2. #2
    Join Date
    Sep 2012
    Posts
    23
    Chauvin LA
    Default Re: John Deere Break in Plus 10w-30
    I'm really not sure if this is non-detergent or not. Anyone ?
  3. #3
    Join Date
    Sep 2012
    Posts
    23
    Chauvin LA
    John Deere Break in Plus 10w-30-image-jpgJohn Deere Break in Plus 10w-30-image-jpg
    Pics of container
  4. #4
    Join Date
    Apr 2007
    Posts
    724
    Northern Lower Michigan
    Kubota B3030HSDC
    Hey,only guessing here.The second picture of the label states the 10W30 oil is suitable for up to 500 hours of use.That would most likely be a detergent oil.Perhaps a little more robust additive package with a little moire ZDDP(zinc)
    I would expect this would be OK to use in anything except the newest automobiles with smaller catalytic convertors-zinc-a great anti-wear additive-is hard on converters and oxygen sensors
    An older truck and your small engines should be fine with this oil .Good Luck!
  5. #5
    Join Date
    Sep 2012
    Posts
    23
    Chauvin LA
    Quote Originally Posted by number two View Post
    Thanks for you input.
  6. #6
    Platinum Member JD 4520's Avatar
    Join Date
    Apr 2011
    Posts
    851
    NW WA
    John Deere 4520
    Default
    Yes, it's not what is in it rather its what's not in it. Should be fine to use.
    Gary
    JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
  7. #7
    New Member
    Join Date
    May 2013
    Posts
    1
    Le Calire, IA
    John Deere
    Quote Originally Posted by Bayouownbeer View Post
    The JD break-in oil does contain detergency additves
Similar Threads
  1. john deere 160
    By edwards200516 in forum John Deere Lawn & Garden
    Last Post: 09-10-2014, 04:35 PM
  2. Replies: 10
    Last Post: 07-03-2012, 05:33 PM
  3. JOHN DEERE 650 DIESEL TRACTOR W/JOHN DEERE 272 GROOMING DECK*RUNS GOOD
    By mr.haney in forum Private Party Ads Archive
    Last Post: 10-25-2010, 02:15 PM
  4. John Deere 790 and John Deere MX5 Will it Work?
    By TerryWorkman in forum John Deere Owning/Operating
    Last Post: 02-13-2005, 04:22 PM
  5. A RED John Deere?
    By rockyridgefarm in forum Buying/Pricing/Comparisons
    Last Post: 11-13-2003, 09:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
